- Feb 3, 2006
Depends on geometry and what is being cut. Lots of people love to cite rope cutting tests. That is a soft, abrasive material. Switch to a hard, non-abrasive material and the results will be different. If we change it up and test steels in a chefs knife model for cutting squash or fish or something else, the results will change again each time based on the geometry, the heat treatment, and what is being cut. Every steel has a set of attributes. It is always a trade off to balance those traits for a desired purpose.
Professions that rely on knives like butchers and chefs almost universally use inexpensive, easy to sharpen knives.
I agree. HOW it's used is also a factor. I read a bushcraft blogger who cited the old adage "a carbon steel knife is easier to sharpen and holds it's edge longer then stainless." Which we all no isn't true right? Sharpens easy, yes. Holds it's edge longer, no. Well, after reading some of his articles it became apparent that he did a lot of scraping with his pocket knife to smooth wood out. For bows I think. In that case he is probably right. A high carbide stainless probably wouldn't hold it's edge as long as a steel like 1095 under that type of use.
The vast majority of the "testing" done is anecdotal. It's a good general idea of how the steels perform but until you get the knife in your hand and use it the way that YOU use it, with the maintenance schedule that works for you, you'll never know what steel is best.
