- Mar 8, 2008
Notice in my video earlier how I pulse the bit back and forth on the contact wheel? That prevents forming a hollow, and creates a nicely blended convex instead. People who produce a hollow when using a grinder on axes are just doin' it wrong.I just started working on a Kelly Perfect DB. It has clearly been profiled to have a felling side and a splitting side. Much of my work so far has been to try and correct the edge geometry. This is my complaint against using grinders to sharpen axes. The round shape of the wheel against the edge of the bit can create a concave edge, not to mention a sloppy curve on the bit.) This was the case on the felling side of my Kelly Perfect. (Sorry, I should have taken photos.) I spent quite a while filing out the concave spots. Additionally, because the felling edge was concave and therefore too thin, the toe was chipped, which required additional filing. Similarly, the heel on the splitting side had a bit of a chip that needed remediation. Aside from the loss of temper concern, I think the electric grinder facilitates poor edge geometry and poor bit curvature. I don't think you can achieve a concave edge with a flat bastard file or a belt sander!
Honestly it's easier to get a convex on wheels than it is to get a hollow. On something like axes you have enough material to be creating a groove that you can then track into, but otherwise holding a consistent spot takes a pretty steady hand.
Makes sense.
My apologies for not being clear. I didn't use a grinder on the Kelly Perfect. The former owner did. In restoring this axehead, I am having to fix, using a file, the mess the former owner made of it.I just started working on a Kelly Perfect DB. It has clearly been profiled to have a felling side and a splitting side. Much of my work so far has been to try and correct the edge geometry. This is my complaint against using grinders to sharpen axes. The round shape of the wheel against the edge of the bit can create a concave edge, not to mention a sloppy curve on the bit.) This was the case on the felling side of my Kelly Perfect. (Sorry, I should have taken photos.) I spent quite a while filing out the concave spots. Additionally, because the felling edge was concave and therefore too thin, the toe was chipped, which required additional filing. Similarly, the heel on the splitting side had a bit of a chip that needed remediation. Aside from the loss of temper concern, I think the electric grinder facilitates poor edge geometry and poor bit curvature. I don't think you can achieve a concave edge with a flat bastard file or a belt sander!
Try using a smaller contact wheel and use something to lean on, like you would with a lathe. It's should work fine that way. I won't say its easy though! Why you would want a concave edge on an axe is beyond me though
It's just amazing how many vintage axes are like this. It's the first thing I look at when I pick up a vintage axe. How much work is it going to take, can it be done and is the temper ruined.I just started working on a Kelly Perfect DB. It has clearly been profiled to have a felling side and a splitting side. Much of my work so far has been to try and correct the edge geometry. This is my complaint against using grinders to sharpen axes. The round shape of the wheel against the edge of the bit can create a concave edge, not to mention a sloppy curve on the bit.) This was the case on the felling side of my Kelly Perfect. (Sorry, I should have taken photos.) I spent quite a while filing out the concave spots. Additionally, because the felling edge was concave and therefore too thin, the toe was chipped, which required additional filing. Similarly, the heel on the splitting side had a bit of a chip that needed remediation. Aside from the loss of temper concern, I think the electric grinder facilitates poor edge geometry and poor bit curvature. I don't think you can achieve a concave edge with a flat bastard file or a belt sander!
Ugh--I hate the "knapped"-looking chatter marks made by the improper use of bench grinders. Arguably, though, you may have come across heads that were properly maintained using a grinder and simply never known it. Those grinding wheels should be used for doing the heavy lifting only, and finished with a file or stone, so if done right then all the signs of it would be gone.
I think you mean common grind.This seems like it might be a source of some common ground?
Don't forget about angle grinders! Even worse![]()
