Steve, heres a little CAD fu. The lock bar slot will be in line like it should. The pic just didn't come out that way. This is not the cutting file, but just a raster of CAD for you to see. You may not get this knife back![]()
This is a little late in coming, but that's a really great idea! Takes a lot for a folder to get me excited.
I like the 1/8" in a folder I really do. It reduces my sanding to use that tremendously which actually reduces the cost by reducing the labor. I bead blast instead of hand sand too which does the same thing. I know some guys like that round handle look but I never have much. I don't mind shoe shining some with the slack belt a little bit to give that effect but using the thickness I prefer to keep from dusting up my shop really restricts how much of that I can get away with and I'm really not capable of doing a whole lot of that kind of sanding with my asthma the way it is even though I wear a respirator. The problem isn't the dust while working its the lingering for days on end afterwards. I may try doing some 3/16" and thicker in spring and summer when enclosure is not such a big issue though but for now I just ask everyone to keep in mind that my shop is without any real ventilation. I'm tapped out for big expenses with the new roof, KMG grinder, and other things I had to do this year to make the shop what it is so far. Ventilation is on the want list but thats as far as it goes at this point. Thanks
STR
Steve,
I'll be happy to make up any thickness you like. I'll send you some samples with that PT clip in a week or two. I've got a bunch of .150" thick denim just now. Not sure what else I have on hand thinner than that. I'll look.
.150 is fine. I use that a lot and have sheets of G10 and Micarta in that thickness. I vaguely remember speaking with someone about a PT so be sure to fill out my work order form with that one. I don't really recall at the moment what I'm doing with the clip. Brain fart I guess.
I look forward to seeing what you have. Does it smell strongly of acrylic when sanded? Just curious. Thanks
STR
Not sure Steve. I have not sand blasted any yet. Lets find out.
Some stuff, especially the burlap, are real easy to work polishing compounds into them.
Most, if not all the the handles in the gallery are just as sanded. The Bark River stuff are all sanded finishes.
After pressing a particular material a time or two I'll be able to pretty much mail the thickness fairly consistently. I cannot duplicate the textured G10, but some materials, I can do some texture.
Thanks for the compliment on the website.
