- Oct 8, 1998
That's the type I had in Western Maryland in the 90s that got lifted out of a campground. Mine had plain black scales on it much like the later Becker's would have from Camillus. Did your's come with those scales?
That's the type I had...
Sorry the prices have climbed so high on the pin-sheath models.
id like to try race someone making 2" kindling....baton vs hatchet
I'm also about to buy a Rat 7, so the LFK probably won't be used to baton.
Go for an RC-6, not a RAT-7.![]()
This is the case (above) in the heavily dry timbered *high desert* part of Oregon that I live in. 2/3's of Oregon is considered 'high desert'...much to the surprise of many. We only get about 12" of rain annually in this part of the state. However, in the Oregon Coast Mountain Range, considered 'rain forest', things are much, much different. It can rain over there for weeks on end and wet almost everything to its core. Having backpacked, teaching wilderness survival skills, played and worked in the wet and damp misty coastal mountains countless times, I can tell you that if you don't split wood, you don't have heat...period. Sticks and twigs don't burn unless added to an already healthy fire. If you don't have an axe, your knife is the next best thing in getting down into some dry wood. I don't carry an axe or chainsaw when backpacking and my knife combined with a baton has provided many a good warming fire for the chilly bones. There is a place for the baton - in the right or wrong environment - depending on your perspective and needs at the moment.![]()
I've had the exact same experience when it gets wet here in the Rockies, as nothing seems to catch fire unless one packs lots of fire starting gel (too heavy) or one splits wood. I just went out recently where it was raining for 3 days and in the high 30s (June in the Rockies- 90 degrees one day, 20s and 30s with rain or snow the next!) and everything was soaked and nothing round would catch fire with conventional means. I had to use a folding saw to cut a small log and a Cold Steel Kukri Machete to split it. I used the dry inner wood for everything from tinder to kindling and then for the main wood. The fire started even in the cold rain using this technique.
No offense but folks that are "fair weather" outdoorsmen have no idea what they could really face if caught in a bad situation in the wilderness. Fires are incredibly hard to start in wet weather, even if you have good tinder and a lighter.
