- Aug 18, 2009
I find both battoning wood and Nutnfancy tedious and mostly unnecessary.
Well I had thought about putting in my post, unless the steel can take it. Because I have seen some crazy INFI flex pictures.
This is a great one. I love how people on here tell others to spend their money though. If I buy a knife just to see how far I can flex it before it breaks. Who is anyone to say otherwise? From the pictures I saw, the knife below went back to true as well.
Infi is some crazy stuff. I need to save back some pennies and get another infi blade again.Yeah INFI is some crazy steel.
I did mine like that just to see if I could crack it or get a set in the blade, neither happened.![]()
INFI is ridiculous. Its dynamic edge stability is unreal to say the least. I have never sharpened my NMFBM and after at least 1000+ chops into hard wood, the splitting of around 60 or more logs, the clearing or brush, and even some fine work it STILL SHAVES. And that was the factory edge. At the rate its going the coating will be gone before it stops shaving. Ive never even stropped it.
Batoning is nothing new at all, I was batoning wood back in the late 70's myself.
I don't understand why batoning is so controversial. I Baton all the time because its the best way for me to make a fire when its wet out.
I have NEVER damaged a knife in any way and Ive probably batoned a few thousand pieces of wood. I don't think batoning is that hard on a knife. Just don't try to split a piece of thick oak with your mora and you'll be fine.
If you have a knife of decent thickness made out of a well HT steel you should be fine. Just baton within reason.... Unless you have a Busse, then go for Madness!
Seriously though, batoning is no harder on a knife than chopping. I don't see what the problem is?
Same here and it wasn't called batoning - it was just splitting small logs to get to the dry stuff inside...
Here is a video that shows batoning is pretty much unnecessary.
Only thing I think he did "wrong" is letting it flame , if you put out the flames , the wood
lasts longer , the embers is enough to keep you toasty warm , and you´ll need less wood.
1234,,,,,![]()
... the knife snobbery over batonning has lead to a lower opinion of this site.
No idea about anyone else, but for me personally if i have a fire then batning is pretty much useless to me.
I split wood to get access to the drier wood in the middle of logs, i do this in very wet conditions as even if the wood has soaked you can usually get drier wood in the centre.
I split wood after i've tried a few times to get a fire going with various hanging dead wood.
If after a few attempts i feel the wood is to wet to get started THEN i will splt some logs.
Once the fire is going well i no longer bother splitting the logs i will just use various types of fires.
For those that are saying you should never baton wood i would love to see you hike 20+ miles a day for 5 days with a axe
I've tried taking a SFA with me and for smaller axes the weight isn't so much an issue as finding somewhere to keep it in my backpack.
A SFA can also be a bit of a nightmare to split some logs in some scenarios.
Also tried various saws but to be honest that's too much like hard work.
So to the folks that are saying "don't baton" with a knife, if you were out for the night, it was cold, all the wood was at best damp and worst soaked and you only had your knife.
Would you baton or would you stay cold and wet that night?
Perhaps it has to do with the milder climate over here in Sweden that I never had to baton anything !
1234,,,,,,,,,![]()
Also depends on if you have a fire when out, or use a stove and if you do have a fire how you light that fire.
Your choice to view other people's opinions as "snobbery."
You could just as easily regard them as a different point of view and not feel offended by them.
For those that are saying you should never baton wood i would love to see you hike 20+ miles a day for 5 days with a axe.![]()
If it´s really cold , I´ll have a couple of logs on the fire , I use matches ,or a lighter to start the fire , I also have
a magnesium block with a fire steel , never had to use it yet .
If you don´t know how to keep yourself warm & dry in the cold & wet , maybe you should stay home . Old Swedish saying.
OK , not that old , alright I just made it up !!
1234,,,,,,,![]()
+1. :thumbup:
Wait, you mean you've never seen someone do that before?That's what I've done since I was a child in boy scouts.
Step 1: lash hatchet of your choice to your pack.
Step 2: put the pack on your back and walk desired distance.
Step 3: remove the hatchet and use it as necessary.
Step 4: repeat Step 1.
I can see why they changed the term...it saves on syllables![]()
