Which ones do you have?any pellet gun you can get that's subsonic and/or has integral suppression, if you have neighbors, is good.
bonus if you can adjust the trigger or upgrade...
the two i have are a little rough, the user is harsh, but i might look into tweaking it later. it's main job is just fun, so, no biggy...
I agree there are better air rifles than the Ruger, but it's a great one if your looking to get into air rifles without spending a lot of money
From a retired Army Colonel, I heard the other day that the Army has chosen this to replace the Beretta 92.
Beautiful. You seldom see those milled receivers anymore.
That Creedmoor sounds like it's maybe not an ideal setup-the brass is not cheap, or from a common parent case, and it appears you only get about ten loadings per case before it goes buhbye.
Why they didn't do a 6.5 off the 7.62 case I dunno...
Unless you meant a 6.5 on the 7.62x39. Which is the Grendel. Possibly looking for a lightweight/somewhat compact 20"bbl bolt-action one for the girls. But since it's made for AR those tend to be light on the ground; could rebarrel somebody's micro-action. Which means I've gotta find a used one, cheap.
I'm betting that Buckmark is a tack driver. My stock one is crazy accurate.
very tempting to get a sniper quality air rifle and a proper scope for it, as well as non metallic ammo (does that exist anymore), else non-lead... the zombi chipmunks are swarming
the spring systems tend to torque from what i've seen, so actual air?
Good spring guns are smoother than cheap ones. Air pistons are lovely Both recoil forward, but the springers certainly vibrate more. I'm not sure there's much torque. As Vik points out, there are specialty scopes for the purpose. Or... give it good iron sights. Depends on the eyes, I suppose. Shooting at a critter beyond 50yd even with a .22 would be silly.
