cbwx34 said:
Lee also talks about belt sanders in his book... even metal removal. For example, he states: "Fortunately, you quickly get used to the actions of the belt sander and will find that you can easily sharpen knives at the rate of about one a minute on the machine without excessive metal removal." (p. 92, empahsis added).
Yes, I thought that way myself for some time until I started looking at edges under magnification and determined just how much of the edge was damaged given a particular state of blunting. Even when taken to very low sharpness, 5% or so of optimal slicing aggression, you are often seeing on the order of 50 microns of metal lost and this is only the coarse stainless steels like S30V which blunt by micro-chipping. On the very fine grained tool steels the metal wear is actually much less.
Years back I started sharpening and measuring the sharpness in steps after passes on the hone and determined as noted in the above that it takes very few passes with optimal microbevels, it is pretty much instant. The math is very simple as I noted in the above. A belt sander turns so quickly that basically every second on the belt equates to 100 passes on a small stone. This makes it obvious that you are removing far too much metal unless the edge is heavily damaged.
The problem is guys who look at the edge after sharpening on belts and visually check and of course it isn't like you see too much metal is removed. If you needed to remove 25 microns optimally and instead took four times as much on the belt sander you would still never see it by eye as you can't tell a blade which is 3.0 cm wide compared to 2.99 cm wide. However if you compared the before and after after extended sharpening it becomes obvious because you are wearing out a blade four times as fast.
This was also discussed in detail with the relevant math years ago on rec.knives during a discussion about steeling a blade to minimize metal loss and just how much metal was lost during optimal hand honing with abrasives. Swaim noted just how little hand honing is required which is why he didn't support that steeling was needed and I did some math and provided some numbers to support his assertion and then did an extended comparison.
I'm also curious... where specifically is this in Lee's book?...
In chapter two which he devotes to how wood is cut he focuses on how the thickness of the blade and the sharpness is what controls cutting ability. He states immediately that you should ignore friction. In the chapter on sharpening chisels he notes why this assumption is a valid one and why you can microbevel and only finish sharpen the very edge which is how serious wood workers sharpen chisels. The reasons why friction can be ignored is that you are cutting with large rake angles and when sharpening the grind lines are perpendicular to the edge and thus surface roughness makes no influence if if friction is significant. This refers to published peer reviewed work.
Jerry Hossom said:
As for the rest of what you've written, my experience and that of some other knifemakers differs from yours.
Yes, that is always a good baseline, vague anon references :
http://www.cashenblades.com/articles/lowdown/lowdown.html
How many well known knifemakers have had the claims they make exposed by the actual science and facts in that article. Cause and effect is not trivial to link. In your comparisons what statistical methods were used to make sure the correlations were not only actually on the right variables but were actually significant. Did you do blind tests, or did you actually tell people they were working with a superior steel/geometry/finish and then expect this to not bias the results. What in fact exactly was compared? What it made sure when you were comparing bevels they were exactly the same in geometry and only the polish was different, or did you use a multi-variable model to insure the correlations were correctly attributed.
Dog of War said:
In fact I've never seen a convexed chisel, or heard of a woodworker who would tolerate a chisel or plane sharpened that way.
I have sharpened a lot of chisels which were convex ground due to sloppy hand grinding. You just grind them back flat and micro-bevel at the required profile. You see the same on a lot of wood working tools unfortunately now because most of them are more utility than wood craft optomized. Typical hardware store axes have really thick convex profiles. The first thing you have to do to make them cut well is not polish this really thick bevel, you have to cut off all the unnecessary metal. Get the profile to the right cross section then polish the very edge.
Some draw knives are convex ground as they are used to cut contours so you want to be able to rock the blade in the cut, some small chip knives are the same. Generally with most wood working tools you
don't want that ability. If you are felling a tree with an axe for example do you really want it to have the ability to easily rotate in the wood, or do you want the grind to act to stablize its movement in a straight line. As an extreme example try to cut wood with a splitting maul and note just how easy it glances and how horrible the penetration is even when the bit is fully polished such as on the Bruks maul. That has a full convex grind, does it cut wood well, of course not because it is way too thick.
-Cliff
