Jerry Hossom said:
... all that time you spent "removing minimal amount of materials" while trying to get a knife sharpened, I suspect you could buy yourself another Battle Mistress.
It takes seconds to sharpen a knife in the manner I described because it is removing the minimal amount of materials. I spent my time working with knives, not sharpening them, this is why I have refined the sharpening I do to a bare minimum.
It is a photo of work done by you as evidence you actually did the work and got the results you claim that interests me. Then again, it really doesn't.
Of course it doesn't just like you ignore the math and the evidence presented which shows you are wrong or even think about the consequences of your comments which would also show they are trivially wrong. As I noted, if the edges on your knives actually did require significant material removal which would warrent being sanded then you would see visible damage/deformation.
Just consider even very fine stropping, ask people who actually use such wood craft knives how often they strop knives when they stop to sharpen them. Do they use a few passes or sit there going back and forth for a hundred passes. Now again do the math and see how many passes on a stationary belt your time on the belt sander equates to. Talk to any of those guys and see if they would think it would be reasonable to keep stropping over ten times as long as necessary.
If you want to see actual pictures then I have many such references provided, you have of course ignored them and the conseqeuences they imply. Several of them are in fact are on chisels specifically, and even on 3V chisels. Landes has not only noted how edges degrade but studed the nature of the behavior and graphed it and it agrees with the model I developed some time ago for edge retention and described here on the forum.
The work by the guys studing plane blades, which I have referenced in the page I wrote on blade evaluation, shows under magnification exactly how much metal is removed, it agrees exactly with what I said. There is also commentary on SwordForums by a metallurgist citing studies of a similar nature and noting the wear on edges will stabilize at the micron level.
Db, as for belt wear and time, it would be assumed of course you are using similar pressure on the belt and the benchstones. In the above, on the benchstones sharpening I noted, the force is very light, about 250 grams, this is not even the weight of a decent sized knife. Note if you actually pressed this light on a belt sander you could not even induce a sigificant curvature in the belt, you would in fact have a flat grind. So the belt sander will actually grind off faster still.
-Cliff
