- Nov 16, 2002
Just ordered another Harbor Freight 1x30 belt sander. Edges beware!
Jerry Hossom said:Any reputable peer-reviewed publication would require you to completely describe the exact method used to determine that your estimate of 250 gram of pressure on the knife edge on the stone is accurate.
Dog of War said:I don't understand, Jerry. You're asking this of others, but when I asked you about the testing that you were involved in with convexed wood chisels, you didn't have anything specific you could provide to explain or back up the claims. Instead, you suggested I was calling you a liar.
Cliff is the developer of measuring cutting thread to test sharpness? WOWdb said:For those wondering the Will York reference is http://www.bladeforums.com/forums/showpost.php?p=3961943&postcount=32
Cliff - of course I didn't really put that question to Jerry expecting an answer. But you raise some interesting points .... in fact I'd like to thank you if I haven't before for all the great info you post - I've learned a lot.Cliff Stamp said:This is standard form, use data to support a viewpoint which is extremely vague to the point of being undefined and have completely undefined references like "other makers" "some guys", but yet place extreme demands on everything and anything which is held as a point of contention. The bias is clear and transparent. I am all for being demanding and critical of data - ALL DATA, not just that which is in opposition to your point.Originally Posted by Dog of War
The basic question raised in this thread is can you use a belt sander to sharpen an edge and not induce temper draw. The answer is yes. The misinformation about other issues such as the behavior of convex vs flat comes from makers like Hossom never defining his edges, which is ironic considering his last post. As I noted recently to Will York, you need to constrain the geometries you can say for example "A circle will have a greater area than a square if both have the same perimeter".
The problem is that the people who are promoting general curvatures never define them. The easiest way to understand why this is necessary is to consider that any convex edge can be considered to be a modification of a flat ground edge which is more obtuse (thinning the shoulder) or of a flat ground edge which is more acute (increase the apex angle). The convex edge will have the exact opposite relationship to those flat ground edges. It will in general (very general) cut better but be less durable then one but cut worse and be more durable than the other. Thus comparing convex vs flat is undefined you have to constrain the geometries.
If I needed to measure what I'm calling the "final" edge angle, which would be the angle of the tangent (I think) on the curve right at the very edge ..... I think I'd just send it to Cliff!db said:I think that is probably a good question. How do you determan what the angle of the convex edge is? Is it the angle of the knife that is held to put the convexing on? Or is it the angle measured at the very edge? and really isn't the angle at the very edge a 0 angle?
I'm sure the Sharpmaker 'method' would produce pretty crude results, but in theory it's sound, I think .... where the rod removes the marking is the tangent to the curve at that point. So you could map the curve of the blade or edge's convex profile. Difficult with home workshop equipment of course....db said:I'm still not really sure you can compare a curve and a flat bevel as a same type of angle. wouldn't the flats of the rods give a false measurement to the curve?
db said:Not real sure how a person would run a test to compare the two different bevels anyways. I'm still trying to really understand how to compare flat and convexed.
