<font face="Verdana, Arial" size="2">Originally posted by Chiro75:
Ho hum.
1) Spyderco Wegner
2) Benchmade Pinnacle/MonoLock
3) Spyderco Endura</font>
<font face="Verdana, Arial" size="2">Hi guys! I figured I had better jump on line to see if I could shed any light on the subjects being discussed surrounding the Spyderco/Wegner Clipit. Before I get started, I would like to invite you all to view the Clipit Story on our knife page at our website www.blade-tech.com.
The question was posed, "Is the Spyderco/Wegner Clipit a hunter's knife or a tactical knife?" In my humble opinion the very things that make this knife an excellent hunter's tool make it a great tactical blade as well -- consider this, its' primary function is to cut flesh!
First, let me explain the Spyderco/Wegner Clipit's role as a hunter's tool. Most people look at a hunting knife as being just a skinning knife and neglect four other very important tasks: field dressing, quartering, disjointing, and caping. All of which can be accomplished without the aid of an ax or saw. This hunter's tool should also include the knife's possible use as a survival tool.
I designed the Spyderco/Wegner Clipit to be a multi-roled knife which will accomplish all that a back country hunter would require of it in the field while working on an elk sized animal, and still keep its' edge. Keep in mind that any knife will dull if it is used to cut through the dirty hair of a game animal.
The design is what I would call a modified Loveless semi-skinner. The original Spyderco prototype which appeared in pre-production photos had a tip that was too wide for intricate cutting, and the belly was too acute and would have been detrimental to its' intended role as a utility hunter. Spyderco made the changes at my request. The only differecne between the custom version and the production version are the point, the semi-skinner hump, and the length. The point is 1/8" lower on the production knife and the semi-skinner hump is slightly less pronounced. The length at 3 5/8" is 1/8" shorter than the custom. I kept these slight variations in the production knife because they make it an even better knife for all around utility without sacrificing any of its' capabilities as a hunter. The weights are as follows: custom titanium - 5.25 oz, custom lightweight - 3.75 oz, production Spyderco- 5.0 oz.
By using the term back country hunter, I am referring to a person who does most of his hunting far off the beaten path. This type of hunting requires the most efficient, lightweight, and tough equipment that you can afford. This is especially true when the fun stops and the work starts, you are fie miles from camp, and you have to make several back breaking trips paking out 150 lb elk quarters. I know I have done it more than once.
The concept of using one knife to do all the field work, saves on the hassle of having to carry three knives far into the field. I must confess though, I always carry a backup folder in my pack or vest and of course it's a plain edge Spyderco/Wegner clipit.
The Clipit blade is dropped enough to open a carcass without snagging the paunch. It's skinning belly is comprised of a gradual sweep that works great removing the hide from the largest game by using an even rocking motion utilizing the blade's full belly, rather than the tip.
Caping is more of a specialty chore and many hunters elect to have their taxidermist do it. Oh yes, I realize not everyone is a trophy hunter, but I'll bet there are a good number of hunters who, like me, will not turn down a nice trophy if the opportunity arises. The knife's tip strong and sharp, not only aids in opening up the body cavity, but more importantly, it's sharpness gives the ability to perform intricate cutting chores where precision control is required. Despite all of this, the tip is still plenty strong enough for the demanding job of disjointing and quartering. I personally know of two AFCK's (great knives in their own right) that were used to pop joints on elk, and now sport screwdriver tips.
The Clipit's lightly hollow ground blade is just right for cutting flesh, but will take heavy abuse if the situation warrants. The edge geometry is great right out of the box. I can personally attest to the strength of this knife as I seriously tried to break one on a big fat mule deer buck right after I received the first shipment in Nov. '97.
On numerous occasions I have even used my Clipit to split wood for an afternoon warming fire on a frozen Montana day. And in a survival situation I would feel confident that this knife will not let me down.
The handle was designed to fit all hands, gloved or not, by using a larger two finger sized cut out rather than a single finger cutout, which in my opinion would have been a less universal grip format. This also makes the handle comfortable for long periods of time in all grip configurations.
I have said all this to say "Yes, the Spyderco/Wegner Clipit is a great choice as a tactical folder." Datu Kelly Worden also agrees, and he has quite a bit of positive insight as to why this clipit makes a great defensive knife.
Yes, at one time Gunsite was willing to promote this knife as the official GTC knife, but Rich Jee and I decided that it would be better in the long run to promote the knife as the utility hunter it is rather than give undue attention to the "new" knife by portraying it as a fighter. Especially if down the road some poor chap were to use the knife to ginsu his way out of trouble and end up in the court system. In the mean time, Lynn Thompson approached Rich about doing a Gunsite Tactical folder and I wholeheartedly gae them both my blessing.
Sal Glesser and his great Spyderco design team did a fantastic job on transforming my custom knife design into a production piece that is not only accurate but one that rivals the custom version in quality. We have sold over one thousand knives and I have yet to find a bad one. The staff at Spyderco are a great bunch and they are a blessing to work with. Sal and Spyderco's integrity are second to none, they have my utmost respect.
Thanks for taking the time to read this long thread! GOD BLESS!
Tim Wegner
BLADE-TECH INDUSTRIES, INC
Tim Wegner
http://www.blade-tech.com
tim@blade-tech.com
</font>
