Do you by chance have a name or a link I can see these jigs? I’ve been gone years and am not current. Thank you.
angle iron on a work rest. Changing angle blade is clamped and the angle you approach the platen changes the shape of the grind.
Don't listen to that advice that learning to grind free hand is something special , learning free hand grinding is just a waste of time.... and someone will never master it
Don't listen to that advice that learning to grind free hand is something special , learning free hand grinding is just a waste of time.... and someone will never master it . With jig everything is faster and more accurate....of course even with jig there is learning curve .
You can grind any type of grind with jig ........ much faster and belt would last longer !
Can you please recommend me a jig for this thingIt came out a bit wavy doing it freehand
joke aside , I don't think such statement is right. Freehand grinding gives you freedom , when you get used to it it also gives you speed and is nice skill to have . I don't say using jig is wrong. I just encourage everyone to try and learn freehand. Cheers
I do wonder what that knife is used for, killing zombies mortal kombat style?![]()
I can make jig for that in ten minutes ..............and in other ten minutes job DONECan you please recommend me a jig for this thingIt came out a bit wavy doing it freehand
About your freedom and speed ..............we can easy check that ? Anybody want that ? We should make complete video .Continuously, from beginning to end .......same hardened steel ...M2 HSS steel for example , same shape and dimension blank .Let see who will do it faster and have better finish , symmetry bevels,even plunge from both side ...etc .You or me with my angle iron jig ????
Come on Freehand makers , let see what is speed , freedom and fast grinding
PS . I will give you 5 minutes advantage............
