This is right, in the end what matters is the quality of the final product. Let's see pics of the best outcomes.Oh, you are in a hurry?
Let's see some of these master pieces you have made with all that extra time for fit and finish![]()
I filmed myself grinding a puukko blade. 100mm long 21mm wide 4mm thick(rhomboid cross section). 80CrV2, not hardened. It took me 6 min 35 sec to bring it to 0.8mm and to be ready for HT. My belt speed is a bit low - 12m/s (2400 fpm) and the belt is half worn 40 ceramic. A friend of mine that is pretty damn good with his hands does this for 3-4 min. He also can withstand much more heat on his fingers than me
By the way is there a way to cross the grindmarks when changing the grit so you can be sure you removed all from the previous one?(when you use a jig)
So yea , noone is saying jigs are bad or wrong. Just give a chance to the freehand grinding. When you have a good control on your hands , it will help you with handle shaping and everything else that you do on the grinder. Cheers
p.s. Please excuse my dirty jacket :d
I agree about learning control.I filmed myself grinding a puukko blade. 100mm long 21mm wide 4mm thick(rhomboid cross section). 80CrV2, not hardened. It took me 6 min 35 sec to bring it to 0.8mm and to be ready for HT. My belt speed is a bit low - 12m/s (2400 fpm) and the belt is half worn 40 ceramic. A friend of mine that is pretty damn good with his hands does this for 3-4 min. He also can withstand much more heat on his fingers than me
Machining is ever more advanced and pretty complicated curves can be programmed now.
For me this misses the point. I spent some time outside yesterday trying to get a dagger to come out symmetrical.
I enjoyed the sense of controlling and moving the grind to where I wanted it.
Buying a perfectly machined blank would be boring.
(Many years ago as a teen-aged weightlifter, my dad used to tell me that there are machines to lift all that weight and more...)
Can’t feel the heat as well as I want with a jig and by the time I load the blank onto the jig, pause and flip and load again, I could have ground two freehand.
Whatever works for you my friend, whatever works.......I filmed myself grinding a puukko blade. 100mm long 21mm wide 4mm thick(rhomboid cross section). 80CrV2, not hardened. It took me 6 min 35 sec to bring it to 0.8mm and to be ready for HT. My belt speed is a bit low - 12m/s (2400 fpm) and the belt is half worn 40 ceramic. A friend of mine that is pretty damn good with his hands does this for 3-4 min. He also can withstand much more heat on his fingers than me
Dan my friend .......... no , you can not grind two free hand while i load..flip....load .....whatever . It is physically impossible to do that .You just can’t have control if you use high pressure and high speed as i can with jig .............Can’t feel the heat as well as I want with a jig and by the time I load the blank onto the jig, pause and flip and load again, I could have ground two freehand.
Why is that important in this topic?Oh, you are in a hurry?
Accept the challenge and we shall see in action what works best
Let see how you grind free hand 5 inch long blade from 5mm thick M2 steel on 64 HRC ?
I don't understand why it has to be either/or discussion
Nice, are those scales g10?Hahaha, you have to be kidding? You think that is a challenge? Here are a few 4" Kwaikens in M2.
You act like this is a hard thing lol
