- Dec 23, 2006
Pootsy never store your knife in a sheath long term. When you are done carrying the knife remove from sheath and wipe down the blade with an oil cloth or rag. Do not soak the blade in oil because the patina from the etch is an oxidation and you will remove it abit with to much oil or rubbing with an oil rag. You will see the rag get a little black when you rub it down. As the sheath breaks in and I have found his sheaths to be of the finest quality and fit it will get a tad bit looser and you will be able to skin the blade from it's sheath with just a quick yank. Alas the patina is going to get mared from this and you will notice the shiney spots or streaks that you are seeing now. What you are seeing is the etch being polished from the blade. The way I even these up is rub it down briskly with an oil rag you will lighten the etch and even out the look of the blade. Alas Eventually you will lighten up the whole look of the blade and that is the price of carrying your knife. I have found that after the sheath breaks in and you reach a certain point of kinda blending the shine spots from where the sheath rubs everything comes together and even though the blade does not have such a dark patina it looks great. You have to figure out if it is going to be a user or a carry piece. I have carried mine at certain times but I carry a regular stag and carbon Bagwell alot more just because I do not want the wear and tear on my Damascus Belle. By the way if you wax the blade you will remove the etch and even ren wax will eventually lighten up th etch. Marine tuff coth works well and I uaually store by blades with that or lightly oiled.. Congrats on your knife again It's a beauty
Here is when I first got my knife you can see the etch is even
Here is after some carry . You can see that in the middle of the blade the etch is not as dark as it was
