I don't have a non superquenched version to compare but It's definately not fragile. I can't wait to see what it does at 20 inclusive. Just need some time to test
SBaker - (publicly) thanks very much for conduct these tests and wrote up excellent & objective review:thumbup:
I've quite a few non-SQ cfv knives but all produced by me, so this blind doesn't really know what a rose look likeYou are my eyes...
edit to add: A high hardness + some RA would be interesting combo at 10dps. I am looking forward to your finding.
You're quite welcome.
People have asked me what this steel compares to, although it only has .75% vanadium compared to s30v, 10% for s110v etc. It seems to make a difference. Its harder to polish the edge with sandpaper than s30v for whatever reason, and takes a somewhat toothy edge compared to 1095 or 420hc which with a decent bit of stropping will end up hair popping but with slide right across things. However don't take that to mean CRV doesn't take a refined keen edge, typically it slices phone book paper much smoother and cleaner than s110v given reasonable effort, possibly even s30v.
Blunt Cut, you said that you have worked with some Blue#2. Have you ever tried 115W8? The best way that I can describe it is it is like Blue #2 with all of the vanadium and about half of the chromium removed and replaced with more tungsten. I think that the stuff Achim Wirz brewed up at the Lohmann mill had over 2% W. Tough stuff. The comment that I heard was that if you are making a slicer, you can leave it at around 64Rc, but if you are planning to "chop nails" you might want to temper it down to 62Rc. That is with the old standard 1500F austenizing temp. I have made a couple of knives with it and been very impressed with the flexibility of the blade at those higher hardness levels. I made a sujihiki out of the stuff and it would take an edge that would cut you if you thought about it for long enough and that was without getting really crazy with putting a "fine finish" on he edge.I have a lightweight 9 inch clip point camp knife blade made of 115W8/15N20 random damascus on the bench now. that was a bot of an adventure to forge weld that stuff!! Might be worth it to find some and check it out.
Jim, thanks for sharing and appreciate your advises.
This is my current approach how to set certain parameters in knife making. Rockwell hardness is just a small window into much large context of metal: grain size, grain boundaries, grain mis-alignment angle, martensite type, RA, carbide volume+size+type. Equally important is edge geometry, blade profile, cutting force vectors and materials. Similarly/actually, I even more particular on hardening temperature & soak time, this too also within the context of how the metal was prepared prior to this hardening step.
115W8 sounds interesting, I wonder how it fares against Super Blue (PM process)? Blue&White #2 knives perform pretty well but my W2 (Aldo 0.94%C) performs better. It would be fun to tinker with UHC steels. For extra wear resistant, I mostly focus on D2, since it's easy to see drastic improvement or degradation. Thus far, I am that happy with my ht of mid & high Cr steels.
Forge weld is beyond my reach right now, so I envious of your fun adventure...
Still a bit perplexed over the patina, I had a 1095 kitchen knife sitting outside coated in the same oil for 4 days 3 of them rainy, and it didn't get a hint of corrosion, must have been damp in the sheath.
Never used either. Beats 1095 in every catagory though.How SQ-CFV compare to W2 and 52100 in term of edge strength and toughness?
