Been trying to reply all friggen night. The forum always takes a dump right when I try to post a long reply.
Basically I was going to mention about the Condor Golok Machete and 42blades' special grade. The blade on the Golok has a distal taper. It is .25" thick through the handle but as you move towards the tip the blade thins out. As it comes from the factory the grind height is the same the whole length of the blade so the edge becomes more obtuse near the handle. If you order from baryonx and get the special grade he will raise the grind and make the edge a consistent angle the whole length of the blade. I prefer that and most others probably would also but it is something to be aware of.
