It is easy to get too focused on one area and leave sight of a few issues such as :
1) They use A2 and 3V, in general two steels which are far more suitable than some of the crazy steels being used in similar knives. Yes you could argue that their could be more optimal choices, but it is also obvious that compared to D2 and things like T15, etc. Bark River is within as close as optimal as you can get without starting to really split hairs and interject a lot of personal opinion and preferences. For example I would generally go with S series over 3V as the higher wear would not be of much use for me and all it has is a lower grindability. But if you let your knives go really dull before sharpening, or you use power equipment to sharpen, or you pay people to sharpen then 3V is likely a better choice, or at least the decision is not so obvious.
2) Bark River came into a tactical world of low sabre-grinds, heavy edges, etc. and produced very thin ground knives. Now yes there is a massive amount of hype and information on the "convex" influence, but just pick up a Bravo vs Steel Eagle and do some cutting - there is a real difference there and you have to appreciate that. Do they occasionally have issues with over grinding, etc. yes, but if they ran TOP's geometry you would never be able to tell anyway.
3) They over a wide range of handle options out of some very high end woods with extremely nice finishes.
4) They have a very active forum which has full company support and active participation. Again you can argue it is moderated to the point Hitler would feel at home, but again there are lots of forums where you ask questions and all you hear is an echo, and there are some makers/manufacturers who have almost no way to contact them to get any information. Would it be nice if it was ran like Spyderco's form and Mike Stewart took Sal Glesser's approach (who defines gentleman), sure but as again, lots of people would pale if compared to Glesser.
5) As much as Mike is made out to be near to the anti-christ at times, he isn't the worst guy on the block in any respect, he doesn't hold a candle to Kevin McClung for example and compared to him Mike is a straight-shooter. If that sounds dramatic then read this and compare that to anything you have heard Stewart say about steels, grinds, etc. :
6)
Bark River, while not as bad as before, it shows without doubt that the companies 3V HT and Grind is a common failure.:thumbup:
[video=youtube;Zu0LJtbWBTg]http://www.youtube.com/watch?v=Zu0LJtbWBTg[/video]
