Cobalt
Platinum Member
- Dec 23, 1998
I have never understood the need for little knives like the Steel Heart
As for INFI, you won't find a steel that has the highest combination of wear resistance, shock resistance, and lateral strength than INFI. It just does not exist. SR101 is not even close. Neither is SR77, which may be almost as tough(but not as tough belive it or not) and can bend as far, maybe even farther, but has no where near the wear resistance or lateral strength.
If you think your knife can, then do these throwing tests thousands of times to your hard use knife:
http://s12.photobucket.com/albums/a220/Cobalt_/?action=view¤t=117_1779.flv
http://s12.photobucket.com/albums/a220/Cobalt_/?action=view¤t=117_1780.flv
Then chop your hard use knife like this and twist the edge out of the wood by torquing it out sideways, do this repeatedly, daily. See how fast you leave divits in the wood and half dime size chunks of steel out of your blade.
http://s12.photobucket.com/albums/a220/Cobalt_/?action=view¤t=CHOPPINGandTHROWING034.flv
then take your hard use blade and throw it into the wood stump so it's tip sticks in 1.5-2 inches and proceed to wiggle it out with lateral movements to see if you leave the tip in the wood at some point. The wood stump has lots of pieces of knives that failed.
http://s12.photobucket.com/albums/a220/Cobalt_/?action=view¤t=CHOPPINGandTHROWING033.flv
Then do all that repeatedly every year for over 10 years and include the chopping of 4 cords of wood. And I am just one of many who have repeatedly used these knives harder than anything else. It is still the best all around steel there is. There are some very great steels that will do all that needs to be done and I have no doubt Fehrman will get you through anything you need to do, so will Scrapyard and Swamprat and ESEE knives sound like they are great for the money. No denying any of these will get you through anything and if you do your part there truly is no need for anything better than these. And I would feel perfectly fine with any of them. Busse is just at the top of the heap. Even with some of the worst factory edges I have seen in a knife. But also some of the best factory edges I have seen as well. If you know how to sharpen or know someone that does, you can turn a busse into a razor easily.
But I do agree that for little knives it is overkill. Although, no one has ever died from overkill.
