- Apr 22, 2005
Seems the idea has been defeated. Oh well.
What's wrong with taking one of these:
and grinding the butt-end flush to its scales? You get INFI goodness and a blade compatible with parts of both SouthNarc's and Floro's methods and principles?
Nuclear Shank or Nuclear Shiv!![]()
you can draw and deploy your pocketknife from your pocket sitting down and in other situations wherein your range of motion is similarly limited. Plus, the act of tightening your fingers locks your knife firmly into your hand in a reverse-grip/edge-in position.
I used to make a knife back in the early '80's called the "Pro Drop" which was short for "Professional Drop Point Hunter". . . It was a 4" drop point with an upside down handle, very similar to Ban's. It had finger grooves along the belly as well. I didn't design it as a self defense knife however. It was designed as an upside down skinner. . . Worked great. . . sold lots of 'em. . . Always started up great conversations at the shows. . . . I'll see if I can find an old blank. . . .
Mike Thourot inspired the design as he has been making upside down handled hunters and skinners since the late 60's :thumbup: I have one of his early ones in my collection. . . Very cool ! ! ! !
Jerry![]()
Here is an interesting Pikal design:
http://www.bladeforums.com/forums/showthread.php?t=539990
LVC
That Piper style is not much different than Pikal. The piper system uses arm traps followed by half beat sewing machine stabs. Pikal is essentially the same with the addition of a rip with the edge in to immobilize the limb should the original attack gets blocked or parried. Once the limb is immobilized and out of the way the sewing machine stabs commence. they say that it wasn't transformed from a stick system, indicating escrima, but if you look at escrima as a machete system using the mentality of "if it takes more then 3 strikes to kill your opponent, your doing it wrong" - I don't see why it's a bad thing.
If you watch the shivwork videos you will see that there is quite a bit of resemblance. The only major difference is that Pikal rips and destroys the offending limb while Piper continues to trap/check the offending limb and stabbing around it.
