OK I have updated the first page of this thread with requests.I have my oven now and will try to get a hardness test before long. If there was some sort of list even if its something quick I would be willing to do some coupons for a few more data points. I have a reasonable selection of steel and could toss something in my next order.
Dang!Just did some AEB-L two weekends ago and totally forgot to make a coupon. :-(
Sounds cool. What was the hold time at austenitizing temperature? What are you tempering them at? Are you surface grinding them to final dimensions?I just hardened 4 1095 coupons and 5 52100 coupons all .187".
The bars were placed in my forge and soaked, cooled to black then i took them into my kiln.
I normalized, thermal cycled then quenched. 2 hour sub critical anneal. Then cut bars into coupons and hardened each one at different Aust temps. Ill be cleaning the coupons and hardness testing monday. If you'd like I can send them all to you after ai hardness test them. I wrote down every step of the process for mt test.
I have aus range of 1095 at 1435, 1450, 1475 and 1500 in parks 50
Aus range 52100 1480 11 second oil, 1475 parks 50, 1500 11 second oil, 1525 parks 50, 1545 11 second oil.
Both bars from AKS, the 52100 is technically Bohler R100
-Trey
Held the 1095 for 7 minutes and the 52100 for 10 minutes. I tempered 1 hour at 280°F all coupons first. Then 52100 at 325°F and 335°F for one hour. I'll be cleaning up the coupons on my grinder tomorrow with trizact belts and will surface grind at 400 grit before testing.Sounds cool. What was the hold time at austenitizing temperature? What are you tempering them at? Are you surface grinding them to final dimensions?
Larrin, I did N690, M2 (low and high temper), Z-finit at higher hardness than the previous samples, 8670 at two hardnesses, and 52100 at two hardnesses. I have to apologize as I thought they were mailed weeks ago, but they didn’t get sent. My hardness tester is reading high, so I ordered a new indented, and have the heat treat regime written out. My numbers are coming out thee or four points higher than expected, and my test block is reading the same.
My wife is go8ng for an mri for memory problems. We think she might have had a mini stroke. I will personally mail them myself tomorrow.
I can commit to O1, 1084, 1095, W2, and have samples of v4e, Caldie, and a8mod sent by hugeo to heat treat. (Going from memory. I’ll double check.) I can do some 15n20 to compare with the weird results from earlier too.
Our sympathies. I hope everything goes ok Willie.
Larrin, I did N690, M2 (low and high temper), Z-finit at higher hardness than the previous samples, 8670 at two hardnesses, and 52100 at two hardnesses. I have to apologize as I thought they were mailed weeks ago, but they didn’t get sent. My hardness tester is reading high, so I ordered a new indenter, and have the heat treat regime written out. My numbers are coming out thee or four points higher than expected, and my test block is reading the same.
My wife is going for an mri for memory problems. We think she might have had a mini stroke. I will personally mail them myself tomorrow.
I’m very sorry to hear that. I hope the MRI reveals positive news.My wife is going for an mri for memory problems. We think she might have had a mini stroke.
