Thanks, Chuck!! And you, too, Warren.I just ordered some thicker AEB-L from Chuck, enough to do at least 40 test coupons (4 ea x 10 conditions). Might have to ask for some help surface grinding, I have one on order but Mr. Wuertz is a pretty busy guy and it is looking like end of the year...
Chuck Bybee, A point I should have asked about earlier . I did a good bit of work in the bearing industry and I wondered which grade of 52100 did you Use . There's bearing , aircraft , and other types . Might make some difference .
Working on some Nitro V
They're all Nitro V.Are these ones nitro v or aeb-l? If Aeb-l, I won’t heat treat any more aeb-l conditions.
Warren
Ok. I have two more conditions in aeb-l, but I’ll see what Michael.Drinkwine has going on. I did 1750f pre-quench, 1975x5min, plate quench, cryo, 250f temper 2hx2, and 350f temper 2hx2. I got Rc62 and Rc59.5 with these samples. I was going to do two more samples tempered at 300f, and 200f. If he didn’t pre-quench, I’ll do these samples for comparison. If he did, were being redundant.
Edit: my tester hasn’t been consistent. My new diamond indented hasn’t come yet.
What's the most efficient way process these samples? Are you doing 3 of each 2.5x 10x55mm or a larger coupon that needs to be cut into 3 pieces?
I just received the thicker AEB-L stock from AKS today, so I haven't done any coupons yet. I've attached a pic of what I have planned, let me know which test numbers you haven't done or aren't planning to do and I will make sure those get done. No sense in doing it multiple times, though!
I am in awe of the level of participation by some of the members of this forum, and the level of personal expense and effort you are willing to go to in order to advance public knowledge. Kudo's to you.
Michael
I may have missed it but any chance of doing Vanax at 60-61 to see how it stacks up as well as doing a2 and o1 as a sort of baseline then maybe s7 as the top haha? I check this thread daily thanks for all you guys have done.
