- Sep 8, 2022
mes sincères excuses, mais je suis curieux de savoir l’opinion des autres sur le résultat des tests de Joe
je suis désolé si j’ai offensé qui ce soit. Je ne froisserais plus jamais les émotions de qui que ce soi …promisYou may express your opinions regarding the knives and / or the tests, but what you can't do is be rude and insulting to the membership.
You've received the only warning you will get.
He appears to be a problem child from what I can glean from his posts both in this sub-forum and one other. He has been banned from posting further in this sub-forum.ThanksBlues that was starting to make my head hurt really bad again.
Nathan posted his thoughts in an earlier post. #94The performance was incredible. So it looks like he introduced a few modes of failure prior to the pole. I'm curious if the lettering on the blade + earlier induced stress caused the blade to break at that specific point. I'm not a ME or materials guy, but it was an interesting spot to break. The lettering has been moved to the spine in newer blades.
Edited to add post number
I hope my post didn’t seem snide! I find myself sometimes missing earlier comments so I wanted to make sure you saw his.Yea the spine damage. I forgot about that. Thank you.
Not at all! I'm still not convinced that the lettering + stress was not related to it breaking. I've seen similar stuff happen in my line of work on vibe tables.I hope my post didn’t seem snide! I find myself sometimes missing earlier comments so I wanted to make sure you saw his.
I'll bet it wouldn't if he started with the pipe.
The spine was dented up and beat to shit at that point.
Mine is pretty hard and it has chamfers, which reduced the damage that mine took, but I'll bet a lot of them have pretty serious stress risers started in their spines before they get to the pipe. And that pipe is a good way to whack the blade pretty hard.
Again, overall I think it was a very good demonstration of my knife and any other knife that's going to get subjected to extended extremely rough use.
While this test was interesting from an academic standpoint, I feel quite confident that if Nathan designed a knife for the purpose of surviving the Joe test that he would be very successful, and the amount of abuse a knife not designed for the test it received actually took looked fine to me.
Most of the level heads on this forum will really admit that just about everything about knife design and the materials for it is a matter of tradeoffs. Low-hardness spring steel sharpened prybars will perform better on this sort of test, but a BFK will outcut them handily. Since most of us get knives for cutting and Halligan tools for wrecking things, it makes sense to design a field knife to do field knife things first and foremost rather than prybar things.
Thank you for sending it in. I found the edge retention amazing.Yep, true - objectively! Creely sent in a knife for testing, and it was a beefed up version of one of his other blades, designed specifically for this test. 1/4" 8670...there was no way it wasn't passing!
The v44X (Work Tuff Gear) had a similar, albeit more dramatic, failure. The edge really opened up, which of course led to stress risers that ended up killing it. The edge also wasn't meant for prying, that snapped too. The more of these videos that I've watched, the more it has taught me about knife design, moreso that steel properties.
I do hope that he ends up with one of those fireman tools to test, or like someone mentioned, a HDFK...which would also be way more up his alley.
