Cautious to put my slippie to work
I'll weigh in because I want to.
I agree with Cory Hess.
I used to work in a saw mill and when strapping and packing sleepers and so forth we used a green plastic strapping which was reinforced with some kind of polymer thread in the centre. Not the soft plastic sort most of you are probably thinking of this stuff is tough. I would never, ever be able to cut it with a slip joint without busting the blade. Cutting geometry is one thing, the thinly ground carbon blades of a stockman or anything smaller are just too small to handle that pressure. Perhaps a sodbuster or a large trapper might have, I don't own either pattern so I can't say. My modern folders were the only thing I felt comfortable cutting that stuff with.
I don't consider cutting down a fridge box to be hard use. It's cardboard against a knife, that's a test of edge retention not the knife's construction.
My use of knives back then tended towards the harder end of things, which is precisely what modern folders are designed for. From material selection through to construction methods they are just stronger. The argument for a traditional construction slip joint is not that it is as strong as a modern folder but rather that it is SUFFICIENTLY strong for most purposes, which it is.
HOWEVER
Slip joints are still perfectly acceptable for most folk's edc blades. THere's nothing wrong with them if you use a knife for lighter cutting tasks but if you want to lean on something and use it as a tool without concern go fro the modern folder.
I will never not own a slippie. They're frankly too gorgeous and fun for me to not own.
P.S
There are very man photos of busted up traditional knives on this forum which were the past work tools of tradesmen. Many folk would buy a cheap knife, beat on it and replace it. Peened joints and pins just aren't as strong as threaded ones and will develop lateral play regardless of the quality of the build, it's just metal fatigue and happens with use. Wheterh that's decades of light use or a year of frequent use is the only question.
I really don't want to sound like I'm ditching on anyone's opinions or slipjoints, I'm just saying that modern folders do serve a purpose in the grand scheme of things
I think that goes without saying. A thick blade is going to have more strength than a thin blade. And anyone can come up with a situation that may require a thick blade. However I have come across those situations so rarely it just isn't worth it and find more situations where a thick blade is just cumbersome to use compared to the thin blade of a traditional.
It's America, carry what you want and don't worry. This is the Traditional Forum, no need for debate, there are differint forums for everybody.
Here's my take on slipjoints vs. modern folders it's really a matter of what you like. I'm retired now but spent 28 years working as a linesman. I built and repaired power and cable lines and used a Buck 110 and a Buck 303 daily in hard use. I used both to strip insulators and sheaths on cable. I scored aluminum sheaths on .500, .750 and I inch coax. Removed polyethylene foam insulator between the aluminum sheath and center conductor. I cut plastic reinforced strapping also. It was used on boxes of everything from power supply's and transformers to bundles of ground rods. I worked 10 hour 4 day shifts and on my off days I built spec houses and used my knifes for everything construction related from cutting drywall to carpet and everything in between and they never failed me.
That said I have had to sharpen them and whack a pivot pin or two but at the same time I have had moderns that have had to be tighten up and sharpened up. By the way I not only own slipjoints but also modern folders and what I have found in my 64 years is a knife is a knife, I like them all and it's just a matter of personal taste.
I used a 70's era Case 3318 for 12 or 15 years as my go to pocket knife. During that time i worked on farms and doing concrete construction. It held up fine but i also think that i knew when i was pushing it to its limits and would then back off. I never really leaned on it like i would have a fixed blade knife had I been carrying one.
There were definitely times when a fixed blade would have been handy but I wasn't comfortable carrying one so I didn't. I just got by the best I could with my little stockman pocket knife.
I know usually carry a modern folder along with a slip-joint. I dont look at the modern as a replacement for my pocket knife but as a substitute for the fixed blade i was never willing to carry. I still use my slip-joint pocket for the same stuff i used to and have the easy to carry modern folder along for when i need something to lean on a little.
I also bought into the myth that modern folders couldn't slice well. I now know that its not true. I have some that will slice with the best of them.
for some of us this is Australia and we also like to pick what we carry :p
