Standard78
- Jun 25, 2015
Uhhhhh... Thanks for the insight on airplane bolts and fan blades even though that has nothing to do with my comment.Airplane bolts that connect the engine to the wing are $2-3000, EACH, and may go much higher for some of those on the spars, which can go upwards of 6 inches in diameter or more.
Just to show those who claim there are no such things as bolts costing in the thousands...
Even better are the fan blades: The most expensive ones are apparently for the Airbus 380, made of Titanium, and they are $ 160 000 for a single blade of about 6.2 ft. in length by 20 inches at their widest...
As to judging my rate of progress on wood you haven't seen, I'm really impressed by your skills. Sincerely. Lots of experience on display in this comment.
This particular GSO-10 is 21 ounces, with a blade 1/4" wider than the Master Cutlery knife, and a much heavier spear shaped drop point that it is almost impossible to get to stick in wood. This is actually a bad feature, because it means it is easier to lay the knife down on the ground where the edge will more likely get damaged. It won't hold still for hands free cutting either... The Master Cutlery is sharply pointed and 16 ounces, with a Full Flat Grind and a slightly thicker edge: Basic physics would say it should be far behind, yet it did about 70% as well. It definitely matches or beat the CS Trailmaster...
There is no anti CPM agenda: People here don't chop wood with their folders, which is why they don't see the apex structure can't take that particular use.
Flex test?! Apparently cutting has something to do with flexing a 3/16"-1/4" slab of steel. Let's keep that precious information in mind...
Gaston
Here’s another useless fact. It is physically impossible to lick your own elbow.
Next time you stab the knife into something, go with the grain. You could also use the sheath that is supplied with the knife. Crazy idea right?
As far as flexibility goes, it is important for most of us who use a knife while carving, splitting, prying, etc.
I’ve had a handful of 4”+ knives in both 440c and AUS 8 that failed under flexing while similar high carbon knives or “super” steels didn’t.
