Cliff Stamp said:[scandinavian bevels]
Full primary ground blades with efficient edge profile are far more effective cutting tools, especially in carving hardwoods as the single v-ground bevel is prone to overloading of the edge due to the way forces are distributed across it. Considering that forces on an edge are not uniform in extent in height it makes sense to alter the edge angle from the edge to the spine. There are really cheap knives which such geometries, an Opinel for example. These blades are also far easier to sharpen, and are far stronger at the same weight than the single bevel grind.
Typical scandinavian bevels are 10/12 degrees per side and 0.125" thick at back of edge, thie edge angle isn't necesary for wood working, unless you are doing rougher work, twisting the blade in the wood, working around knots, etc., such as Mears does with his in the Bushcarft series. If you are just cutting with the knife you can cut that edge angle in half on a decent steel. The edge thickness is also way overkill, even heavy tacticals are a third of that thickness and for a simple wood cutting knife it is ten times as thick as it needs to be which also means there is ten times as much steel to sharpen.
-Cliff
I guess the Scandinavian people that have been using this type of edge for a zillion years for woodwork, butchering, everything, don't know what they are doing?
And Kochanski? Mears?
Ten times as much steel to sharpen? The Scandi grind is the fastest, easiest type of edge to sharpen with a flat stone, ceramic rod, whatever. Lay it flat along the grind and stroke. Repeat. Done.
The fact is that Mors Kochanski has a heck of a lot more experience and knowledge than most of us. As does Mears. Same goes for the traditional Scandinavian people that lived off the land. Or the Inuit, Dene, & Gwich'in people.
Another fact is that if you have to make a fuzz stick to start a fire, or produce thin shavings, nothing works like a Scandi grind. This I know because I have done it with dozens of knives, hundreds of times.
Some people have a bias against the cheap thin moras, because they are not good for chopping cinderblocks of breaking open nailed wooded crates. And if that is what you need to do to survive, do not buy a mora. Why, though, you would need to do those things to survive, short of military operations, I have no idea.
I am not saying that the best knife in the world is a $5 Frosts knife. The question was about cheap knives for survival. The best cheap knife I can think of is indeed a Mora type knife, due to its cost, weight and capability. I say look to the survival experts, not the forum-posting experts. Ray Mears and Mors Kochanski, to name a few.
Throw in a lightweight pack saw and a GB Forest Axe, and you have it made.
