There's a bit of crap and misguided speculation in this thread....
I'm not going to consider the opinion of anyone suffering OCD,
 or any other mental illness, as fact. If you want a perfect V-edge on your knife and start to palpate and sweat if it's slightly off, power to you. Sharpen it to still your rapid heart, go about using it and read no further. Best of luck to ya.
As far as being a "sexier" edge......
c'mon.
  Hard for me to relate "sexy" to a blade edge. Maybe to a blade, but not an edge...which does the actual cutting.
If you guys think you don't own any chisel ground blades, look no further than your manual razors. The blades are chisel ground. They are the sharpest blades you own. Less expensive to manufacture you say? Have you checked the price of blades lately? Overpriced as Sebenzas. If V-ground were better for cutting they'd be on the market--it's not overly expensive to grind one more side if you're familiar with razor blade manufacturing machinery. There's a reason for chisel grind instead of V--they technically cut better, potentially sharpen better and hold an edge equally well in most instances.
In the razor blade industry, sharpness and longevity being the grail, if V-grind were stronger, sharper OR produced a more long-lasting edge, they would be produced and on the shelf. The razor industry will also tell you that the average man's beard is like shaving the equivalent of equal diameter COPPER WIRE. It's the base criteria they use for testing blades. Check it out. If the experts in sharpness choose chisel for such a task it's going to be fine with me.
As for BLADE strength: obviously given two equal blade blanks, one ground on only one side, the other ground away on two sides, the one ground the least is going to have greater strength; be a "stronger" blade (and resulting tip), having had less steel removed. This has been my experience over time in using both.
As to EDGE, I see no reason a chisel ground edge would be any weaker than a V-ground edge. IMO, the opposite is true if anything. And if an edge does chip or roll, it's going to be recoverable a hell of a lot faster and easier on a chisel grind. Easier for field touch-ups too. Simpler.
If you can't cut a straight line with a good chisel ground blade,
or at least train yourself to in under 15 minutes, you need to go back to kiddie scissors. Personally I can cut equally well with V or chisel grind. But I can make more ACCURATE cuts with chisel. Cuts "cleaner" too with most materials, as they can be incredibly sharp just due to the nature of same, not having to sacrifice sharpness in favor of looking pretty or painstakingly achieving an equal angle on the other side for the visual proclivities of some.
I've said in here often, as I'll say again, I've never understood those who state that a chisel edge is not good for EDC. I have many V-ground as well as chisel blades. I've never ONCE wished I had a V-ground blade instead of chisel while attempting
any EDC task. If anything I find that chisel grind cuts a bit better, all things considered, both being sharpened to the max. In fact, now that I think about it, there have been times I wished I had a chisel ground blade with me INSTEAD of a V-ground when I need extreme sharpness, as when splitting leather boot lace or having to shave the sueded side of leather smooth in a tight area (where a chisel-ground Leatherman blade really shines).
I don't obsess over chisel vs. V any more than I would obsess over steel or handle material. I buy a knife if I like it regardless of grind.
However....to in any way lessen a chisel grind compared to another grind for use has never even crossed my mind. Chisel grind makes good, strong, sharp blades. In many cases cutting better than typical V-grinds.
I believe that for the most part, those who demean chisel grind, much like those who demean tanto blades for EDC, don't have a lot of experience with that type of edge and are just freaked because it's "different." If they were less than satisfactory, in the decades I have used knives in every environment, I'd have experienced it.  The blade doesn't go off the road, in circles, or disjoint my wrist when I cut with it either. Poor babies out there who can't follow a straight line with an edge....sheesh.
One exception may be in the kitchen. I'm not a carrot-slicer so I wouldn't know.  But then I see where many times a chisel grind is preferred on some of the better/prestige kitchen knives...maybe moreso even than in our little world of folders.  Go figure....
