The 30 degrees is on the secondary bevel. The primary bevel remains unground on one side of the Chisel example and the cross-section is thicker the entire length of the blade from spine to edge at each corresponding point along the blade. Again, assuming the blade blanks are equal on both prior to applying the grinds.
It's not about being right or wrong really. I was just offering opinions based on the geometry and physics. Having more material backing an edge and tip is always a good thing if strength is a primary desire. Grinding only one side of a blade blank is always going to give you comparatively more material backing. But debating about blade designs and pros and cons can't really match real-world experience with chisel ground blades, of which I have none other than working with standard chisel tools for home utility tasks. If you try the blade style and it works for you better than something else for the types of tasks you typically perform, then it is of benefit. That's really all that matters in the end. But you won't really know for sure until you try the design. That will deliver the verdict for you.
Take a 1/4 inch thick steel blank; grind one to a Scandi edge and one to chisel and both to 30 degrees (inclusive). Now measure 1/4 in back from the edge and measure the thickness of the steel. I would bet they are both the same! So which has more material?? Which is stronger? You can sit at a table and draw this on a piece of paper with the same results. For some tasks a chisel (scraping) edge may be more efficient, but stronger, No.
So, is Bubba describing a full flat grind? Does the FFG change the math?
I think the distinction between primary and secondary bevel is where the confusion is. If we start with two blanks then proceed with the grinds: Create a full flat grind with a primary grind thickness that is arbitrary. Make it any angle you please. On one blank, grind this primary bevel on both sides--full flat from Spine to edge. On the other blank, grind this same primary flat bevel on only one side. At this point, I think everyone will agree that if we took a caliper and measured the thickness at every point on the two blades, we would find that the thickness at each corresponding point on the chisel grind would be greater. Less material has been removed. Now apply a secondary bevel to the edges. Again, completely arbitrary. Whatever you please. Apply this bevel angle to each edge of the dual-ground blade. Now apply this same bevel angle to the single ground edge of the chisel grind. Take out the caliper again and measure the thickness of each point on the two blades. Again, the thickness would be greater on each corresponding point of the chisel grind. Less material has been removed. More material has been removed from the dual ground blade. Both sides of the blade have had material ground down. It cannot have a greater thickness/cross-section.
So you're saying the chisel is blunter and doesn't cut very well as a result of being "thick"?
There are a number of fundamental errors in some of your assertions, most of them pertaining to the specific context of the work being performed. You might want to watch the video that 1234 was kind enough to quote to this page if you haven't already and think about in what circumstances one configuration would be preferable to the other. There are a number of good reasons why both blade styles exist and are traditionally found most frequently in different settings. One is not globally superior to the other, so much as they are simply adapted to different contextual applications.
Chisel grind and chisel edge are two difference thing.
All straight razors are hollow ground with chisel edge.
The reason why production razor use chisel grind because the flat side will create less drag on shear type of cutting and its also cost less to produce.
Same reason for Scissors, Wood chisel, Wire stripper etc.
I am not saying anything other than all things being equal, grinding only one side of a blank will produce a stronger edge for the same reason a thicker stock produces a stronger edge--more material is left to back the edge and tip. Again, it is all relative to the bevel angle applied and there are many considerations that go into a design. You could create a chisel that is thin enough that strength is not an overriding property and the emphasis is sharpness. I also don't think that strength is the main reason that the chisel grind is employed in all applications. But if one of your primary goals and consideration for use in applying a grind to a blank was strength, a chisel grind would be a good candidate. Sharpness is another property altogether that will depend on choice of angles and stock thickness. But one desirable property of the grind itself is strength and durability if you were to be headed in a direction that favors these attributes over others and wanted to grind out a blank with this in mind and were limited to a particular stock thickness.
Your post is interesting, but they are not the sharpest I own. The sharpest I own are scalpels, and they are V-Edge. Here is the specific brand's patent that I have with Figure 2 being the cross-sectional view.
.......Only thing I haven't seen mentioned extensively is that chisel will leave a much nastier scar/wound due to it's geometry in separating flesh. Obviously both grinds cause damage but typically v-grinds heal better and chisel scar more and take longer.
-Nick
I designed this knife and Charlie Mike made it for me. It is a chisel grind on the right side. This knife was meant to be used and the chisel grind is there for a reason. I make a lot of canes and hiking staffs and shaving off the bark and roughing out the shape is
one of the reasons that I wanted this blade. It can also make a great EDC blade and I find it useful for many of chores. Chisel grinds go way back, but look at the history of bread knives for a clue as to why a chisel grind. It's really that simple.
