What's "not cool" is to define the proper function of any tool by whether it breaks when you deliberately abuse it.
This is no deliberate abuse but real life test.
Once again for you (is it 6th time?):
He introduced knive - as A2 thick heavy duty one piece...
http://www.youtube.com/watch?v=T0H8EFC26vw
1. Peel apple, (I tests on potato) - shows basic ability to use knife for "fine" thing like food prparation, reasonable test and Project one doing all right.
2. Slice an apple - reaonable test to me - show that blade is bit too thick for fine slicing.
3. Cut 10000 pounf ribbon cutting
4. Control Cutting of 10 000 pound ribbon
5. Cut same with serration
6. Chopping 2x4 - not a good chopper according to Noss4. get some energy to do. not heavy enough...
http://www.youtube.com/watch?v=HZ2fT6pL4xQ
7. Cut 10000 ribbon after chopping - cut well no difference on the edge.
8. Batooning firewood hitting with wood - done.
9. Cutting Ribbon after batooning. - less sharp.
10. Tip break test on 2x4 "dig through" - perfect shape after testing
http://www.youtube.com/watch?v=3VmWJOAJB5I
11. Tip test on metal - snaped off very tip few mm but no any serious non fixable, compare holes with holes from other knife. Reasonable test for survival knife.
12. Batooning through 2x4 with 3 pound steel hummer
I would say he hit it very gently, defenetely without intention to destroy it with blade about 60 degree to wood) until at 8 minutes it breaks very easy without actually any hard hit and at the different point from where he did hit it with hummer, but near handle. Also it was clearly surprise for Noss4 he did not really expected this.
So is it deliberate abuse?
Thanks, Vassili.
