- Oct 17, 2015
Im missing the clip on the 2nd knife from the bottom. No sheath but wouldnt be hard to build one.
That early Titanium model (186) has a belt clip rather than a pocket clip. It is meant to be carried outside the belt or waist band on the right side. If you remove the clip, it will fit in a 110 sheath.
The 560 Titanium models were put together with .125” diameter stainless steel pins. Heads were spun onto the pin at each end. It is quite easy to replace the rivet with a screw set. The hardest part of installing a screw set is getting the rivet out. You have to behead the rivet with a Carbide spotting drill, and once the drill gets a hold on the rivet, it spins. At this point you’re looking at grinding one head off with Diamond ball Dremel bits.You should offer the conversion from riveted to screw together. I have 2 I would send.View attachment 1043833 The model 560 Titanium models were put together with .125” diameter stainless steel pins. Heads were spun onto the pin at each end. It is quite easy to replace the rivet with a screw set. The hardest part of installing a screw set is getting the rivet out. You have to behead the rivet with a Carbide spotting drill, and once the drill gets a hold on the rivet, it spins. At this point you’re looking at grinding one head off with Diamond ball Dremel bits.
Screw sets look like this.
I suspect, its a batteri held on by elastic bands to keep the lock depressed when working on the knife.Hi tiguy7 what are the rubber bands holding on? Looks like a battery? A battery powered knife? LOL!!
Boy is it a pain when the rivet starts to spin. If you have drilled deep enough you might can tap the rivet on out. Otherwise, you'll need a Dremel bit and those don't last long so get several. DM
Hi tiguy7 what are the rubber bands holding on? Looks like a battery? A battery powered knife? LOL!! I see it is holding open the lock so the blade can be pulled out straight. I do like those bit holders. Are those screws smaller than 4-40?
View attachment 1044058Those are made by Rain.Z knives. They’re made out of Titanium and have ceramic bearings.
