- Feb 8, 2013
Army beat Navy! That is all
Nice, I've used a small biner with the large locking biner to do the same thing. How's it working for you?My GriGri grew a Freino.
Looking at the Stihl MS 180...
Better option under 300?
Don't need a very big chainsaw... Mostly only need to cut 10-12" wide, or smaller, trees/branches.
if used, and in good shape, go for it... clean it, make sure the oil flows, get a "yellow chain", and use it up.
if new, 181C i think is the slightly better option; most place will double your warrant if you buy the require additive at purchase time.
get a "smart wood holder" too, for fun times (or make one)
....yellow chain?
The more answers i get the more questions i have... What a rabbit hole i have fallen into.
So the silver chain i got is a "safety" chain... The real deal chains come in yellow color... Correct?
My bar is 16" so do i just need to find yellow 16" chains?
Oil spraying? I haven't seen any oil spray anywhere lol. The salesman just said make sure i keep bar oil in it and check it before use to make sure it's not empty..
No chaps yet... But I'll get some soon.
Kill switch... So this is my first chainsaw...so I'm prolly not calling it the right name... And this stihl has the easy start system which might make this different than other saws...
But.... Where the switch is to put it on choke there is a full choke, half choke, on, and off setting for this switch... But the saw stopped turning off when i put the switch up to the off setting. I did some googling and apparently it's not that uncommon of a problem... But an easy fix normally.
I'm not sure if it's related, or a normal feature, or? but even after i do turn the saw off i can hear a hissing sound... Its faint but noticeable. Like air leaking out of somewhere... I'll bring it up tomorrow when i take it to be worked on though.
The air leaking out MAY be coming from the bar oil reservoir. While the saw is running, air is pumped into the bar oil reservoir. This is what pushes the oil out onto the bar during operation.
When you get done cutting, you should completely remove and then replace the bar oil reservoir closure to release the pressure. Don't just crack it open. Remove and replace. Leaving the reservoir pressurized is what causes the oil to leak out while it sits around waiting to be used. Depressurizing the reservoir will prevent MOST of the oil leakage. There will always be a little leakage, but failing to depressurize the reservoir will result in copious amounts of oil running around the chainsaw case.
Well it's been hours since it was running and it still making a very very faint sound.. Maybe air, maybe not air... Maybe a winding sound.... Bizarre.
Regardless it's going back in the morning but first I'll go try opening the oil reservoir.
Bladite this is a 180c and has the switch like you describe and like said doesnt shut off in off mode..
It's obviously defective.
Thanks for all the info and tips fellas!
in my actual extensive research so far, Husqvarna 40 is better due to "several trhings"
google it![]()
no. off is off. full stop
exchange / return...
if they give you shit, smile, and say "well, i'll call corporate as this is a safety issue"...
google it![]()
The wifers got me a Rinaldi Trento from Baryonyx. 'Twas my b-day yesterday:
Hate indoor photos, but I just had to do it. What a beast:
Also, it's been below zero here for days. I get to go fishing soon!! Was gonna try tomorrow, but I was advised by a friend of mine that is a guide, that I should wait a few more days before I venture out on the ice. Maybe Thursday then.
