I didn't know that, thanks for heads up. I will have to check it out when I am way out east.
What are your opinions on Kees Van Der Westen? Copa Vida and the new Blue bottle in Venice has the Spirit. I checked out the single group Speedster and the baseline started out around $12,500.
I'm never sure how i feel about lever units i used a friends nicer pavoni and it took a ton of practice to get something even drinkable.The Kees IMO has a very classy look and the Slayer has that bad boy look to it. Have you looked at their Idrocompresso?
My mind wont stop thinking of how to install a direct plumbing system for one of those dream machines: LM, Synesso, Kees, Slayer, Londinium. I have seen posts of people using a flo jet system and a big water container but with all of the filters, PPM, pH balance, scale, and remineralization, makes it all expensive and time consuming. I will probably still need a plumber to put it together efficiently. I guess only in my dreams.
I'm never sure how i feel about lever units i used a friends nicer pavoni and it took a ton of practice to get something even drinkable. i guess it is a pid controlled unit though, that would probably make a differenceThe Kees IMO has a very classy look and the Slayer has that bad boy look to it. Have you looked at their Idrocompresso?
Yeah temperature stability, which means consistency, is the big problems with manuals but IMO when done correctly can make your hard work feel more rewarding. I am drawn to the manual operation, pressure profiling, and their simplicity. Pavonis are known to have many problems but Olympia and Londinium have most of their stability problems figured out.
I wouldn't want one in a busy cafe but at home when you have more time to spend on the details. The Funnel Mill in Santa Monica uses a Rancillo manual lever. It was one of the smoothest espressos I have had in LA.
What are your favorite ways of brewing? Are you into the Cold brew craze with those big jugs?
P.E. that ZT 454 is very cool. I love the CB blades. I thought the JYD was impressive then I bought a CB Leek...now that. If I wanted one -- about how many $1 McD's coffee's would I have to buy to equal the value of that beauty???
im a espresso and chemex guy, not a huge fan of cold brew i like it but its not my favorite. Press-pot is good too depends on the coffee though. some coffee works better than others. i was drinking some Highwire Honduras from up in oakland today, it was pretty delicious, nice date and Carmel notes.
Check out ZPM Espresso
https://www.kickstarter.com/projects/zpmespresso/pid-controlled-espresso-machine
Machines are way way behind schedule, but I'm staying positive that they will deliver. Apparently having some UL certification issues.
