- Mar 8, 2008
"One test result is worth one thousand expert opinions."
Wernher Von Braun
A favorite of mine:
"Experience without theory is blind, but theory without experience is mere intellectual play." ~Immanuel Kant
Wernher Von Braun
Wernher Von Braun
FortyTwoBlades- Yes, I adapted my technique to the poll less ax. The repair of historic buildings, and even my early work years logging, required a lot of technique adaption with a wide range of tools. Also, it was not the first or last time I used a poll less axe. I still use them today for historic accuracy. A good craftsman can adapt quickly to a different tool. Best example I can give you is a woodworker you all know- Norm Abram, PBS star of "This Old House" and "New Yankee Workshop." I was a guest craftsman twice on "This Old House." I took Norm to log restoration projects in Wyoming and then 4 yrs later in Montana. Both these restoration projects were in wilderness areas-this means no power tools of any kind. Now, as you all know, wilderness and no power tools are not Norms thing. He adapted extremely quickly to tools and techniques of which he had no prior knowledge. The viewers certainly could see this happen on the shows. Norm is a nice guy and great craftsman.
Lets come at this a different way. Give me one good reason for our 18th century American settlers to have developed what we are calling the American poll axe if it was not a more efficient cutter.
Now tell me why all the world titles in competition chopping are held by Polled axes if poll less axes are as efficient choppers?
In what way is it more efficient, though? Define what you mean by that.For instance, I personally find that my Italian axes (the ones in my personal stable) have lighter heads on longer handles than similarly intended American counterparts, and while those American axes would get the job done a bit faster with their heavier mass, the Italian axes get through in almost the same time and I find myself using much less energy. Since I run the homestead almost exclusively on hand power, being able to save my energy for other tasks during the day is of great benefit. However, that's mostly a function of the long handles, light heads, and deep, thin bits. Those same axes could have the handles brought more naturally on-axis by adding mass to the poll, but that would increase head weight. The head weight could be kept static by simply shifting the eye position forward, but that would shorten the depth of the bit and reduce clearance. The poll-less designs prioritize the deep bit and low head weight combination over on-axis handle construction simplicity and pounding functionality.
I have nothing against polled axes, and do have and use a number of them. I just find that the function and advantage of a poll is something that's often talked up, without much attention paid to whether or not those assertions are actually true.
FortyTwoBlades- I define efficient as-a poll ax moves more wood than a poll less ax in the same length of time.The increase in efficienece you describe with a longer handle is the same for poll ax or poll less ax.
It might be time for you to start a weight training program if cutting with your poll ax is making you too tired out to do your other chores. I have never had that problem.
b) the polled axes allow for increased efficiency regarding the amount of wood moved;
c) poll-less axes allow for less energy expenditure;
Traditional axe patterns die hard. Many regions cling to old patterns out of habit. But all the old world patterns came to the new world and were thrown into the crucible of trial and invention. Forestry became an industry on a scale never seen anywhere else. Woodsmen learned what worked best and they wanted it - needed it - to stay competitive. And they invented the American poll axe. Still unequaled.
