This drawing shows three convex edges overlaid on a V edge.
The first two convex edges on the left share the same edge height and width as the V edge. When convex edges are compared to a V edge with the same edge height and width, the convex edge is always more robust because it has more steel behind the apex. However, how much more robust depends on the amount of curvature in the arcs that form the convex edge. The far left convex edge is much more robust than the middle convex edge because is has more curvature.
So even when the edge height and width are held constant, a convex edge can have a wide range of performance that will affect both edge slicing ability and edge robustness. With a V edge, those performance characteristics dont change as long as the edge height and width are held constant.
The third convex edge shows that a convex edge can be made more acute by raising the edge height and keeping the V-edge height constant. Raising the edge height has a powerful effect on edge geometry and performance.
Edge width (width of the edge at the shoulders) also has a powerful effect. You can see this effect in Ankersons epic thread on steel performance. Even when the edge angle is held constant, an edge with narrow shoulders will outperform a wider edge, even when the steel and edge angle are held constant.
Because edge width and height have a powerful influence on edge performance, you have to keep them constant if you want to compare the relative characteristics of convex, V and concave edges.
With a V edge: The more narrow the edge shoulders and the more acute the edge angle (which is made more acute by raising the edge height), the greater the slicing ability and the less its robustness.
With a convex edge, the more narrow the shoulders, the greater the edge height and the less curvatures in the arcs that define its edge, the greater its slicing ability and the less its robustness.
