Convex edges have less steel behind them but are still tougher.
Toughness is not simply about the amount of steel. To assert this is to over-simplify the dynamics in play as the blade moves through the medium being cut.
A convex edge has stability for the same reason that a stone arch has stability.
https://www.youtube.com/watch?v=XA5AM2Lb0iY
I also reject the assertion that we should only consider edges with the same exact apex angle.
My contention is that a convex edge cuts just as well as a v edge, even if the apex angle (as measured by tangents) of hte convex edge is wider. The absolute apex only matters for a very short time during the cut and slicing has as much or more to do with what is happening at the shoulder of the edge, or just behind it. Putting this another way, I think the angle to compare to is the shoulder angle, not the apex angle.
Compare the following:
1) Pure 17 DPS v-edge
2) Angular compound edge with 17 DPS back bevel and 20 DPS apex
3) Convex edge with effective 17 DPS final back bevel and 20 DPS apex
My contention/experience is that the latter will slice just as well as the first due to the 17 DPS back bevel while being stronger due to the rounded and wider cutting apex.
FWIW, a slight bend in a Lansky rod will reliably produce a 20/17 convex edge.
WoW. I don't think it can be said better. You just added a really important point. I hope this gets laid to rest with your post.
- T
