Country of origin
Hi. Yes, country of origin is a topic popping up often here :D. Interesting reading. Since the conversation mostly revolved around China and Chinese knives, I think I can add a few lines on this, hoping not going too much OT :).
I have been working and living in mainland China for 3 years, ending my assignment rather recently. Working with QA, I have spent most of that time on Chinese factories floors, dealing with suppliers producing consumers goods, some producing table cutlery. This, I think, is rather comparable to sporting knives production, at least when it comes to main industrial processes.
I was not short of quality issues with them :D! Problem was our made in China stainless steels table cutlery oxidized and eventually rusted like - and sometimes even more than - EU made carbon steels. We run a project to fix the many claims and we identified the problems root-cause connected to three things: the raw materials, the grinding and polishing processes and the finishing process.
First thing we started to analyze and compare the steels. When managed to perform ourselves a cast analysis in a own lab, it turned out they were not exactly the same in composition, compared to EU standards (even though the standards conversion table claimed they were), and their performances were not at all to the same level. This was valid for several others raw materials I worked with, plastic for example. A Chinese made PA6 was not always having the same properties as a EU made one, even if same plastic producer run the two plants :confused:. The plastic producer themselves couldn’t explain exactly why. Being not possible, for cost reasons, to import steels or change to a proprietary (with a modified composition) domestic steel, we had to work with incoming batch testing for key parameters (and restricted substances) and sort quite much. A pain in the a$$.
The second issue we discovered it was about the compounds used in the grinding and polishing processes. The factories were building the grinding and polishing wheels in-house (on the bare floors sometimes :)), they didn’t buy any "industrial standard grade" ones. The problem was that, in the making of polishing wheels in-house process, compounds containing sulfur, calcium oxide, iron oxide, quartz, rosin, etc. were used. Clearly, this stuff used in the grinding and polishing developed oxidation and eventually rust in the steel microgrooves. Also there was a real problem in measuring properly the agreed surface roughness which, for example, for a satin finish (in the table cutlery) we agreed on values Ra max 0.8 μm and Rz max. 8 μm and for a mirror finish Ra max 0.25 μm and Rz max 2.5 μm. There were simply no appropriate tools to measure! Or, sometimes just shortage of experienced operators to use tools. Was impossible to have a verification of agreed values.
Third issue was the quite poor finishing. This was mainly a cultural/behavioral/mind-set issue. This is not only China, to be fair :). But China has it in big scale. All of us who have experienced factory floors mass production of consumers goods, can recognize that, when dealing with hundred thousands of pieces running through our hands every day, we lose a bit the idea that one piece is one Customer. We just see tons of the very same stuff :D. The lines need to run, they tell us and this is when speed and quantities come before quality.
First two problems were about “things”, it was relatively easy to tackle and solve them (hardest DMAIC phase was the C :)). The third one was about People, much more difficult to get through, as usual… :) and this would bring me to politics/economics which I’d rather not talk about. Anyway, most of the things said here about China are very true. Overall, I think that People get the Government they deserve. The good and the bad attitude/behaviors we point out in a Government it’s many times just the big scale reflection of the individuals very same good and bad attitude/behaviors. This said, I actually don’t own any Chinese sporting knife or made in China knife yet.
Undoubtedly, some parts of China are great, just as some are not, and your friends would surely not be going back if it was to be worse off than they were while in Europe. You can't use a broad brush to describe a country with a population as large and diverse as China's, and I didn't word my previous post in a way that suggests that things are bad all around. However, between human rights issues throughout the country, extreme pollution in some cities and extreme poverty in some rural regions, there are major problems affecting huge numbers of people that we don't hear about very often if at all. The disparity in infrastructure between urban and rural areas is an exaggerated version of, for instance, rural American communities compared to cities.
Also worth noting is that China uses residency permits to control the movement of people between areas, which means that people living in impoverished regions can't simply move to the city to find a job. The government needs to OK the move. This not only affects poor regions, but also those of ethnic minorities who are effectively restricted to living in the region dictated by the government. I've watched a couple documentaries showing this, but I don't recall the names. In any case, when I mention North Korea, it's because many of the rural areas of China (again, many times inhabited by ethnic minorities) have little or no modern infrastructure, are subject to more hardships due to famine and natural disaster than other parts of China, and really have no recourse that would improve their conditions.
The same could be said for pretty much most of the world including parts of the United States and large parts of Europe.
Not a word about your poor comparison to North Korea though. Didn't think so. China might not be wonderfull......but NK is a special kind of hell.
Quite an interesting post Herlock. For me mostly because of the stuff about raw materials. I'd heard that before, that the standardization of raw materials for manufacture wasn't what it should be.
A place where I used to work quit outsourcing parts from China partially due to materials. A sheet of stainless stock for the laser had a half melted bolt in it.
I interviewed for a machinist job once and the conversation turned to countries the man bought parts from and their cultures. He said Chinese vendors were funny. The would offer very inexpensive parts which would turn out to be incorrect. When called on it they would say "But they were cheap!". He could get correct parts for a bit more.
So China can make quality stuff and it's very good at mass production of "pretty good" stuff. They own inexpensive consumer goods like the garment industry.
As usual in these threads, everyone is right. You can get a decent knife from China. They are an evil empire, but so are we. They treat their workers poorly, but rank and file workers in the USA aren't exactly treated like gold. This USA blue collar worker isn't going to make much of a difference boycotting their knives, especially when he is almost forced to buy Chinese stuff of every other sort.
So the business of business can be evil and maybe China is a symptom and not a disease.
I will say this. I don't think China is unrestrained capitalism so much as unrestrained capitalism combined with communism. The government moves into rural areas and builds planned manufacturing towns which employ the displaced p̶e̶a̶s̶a̶n̶t̶s̶ rural folk.
How can a purely capitalist society compete with that?
These are just the ramblings of an unkempt mind and I reserve the right to decide to defend none of them. Just another bump in the road as we hopefully evolve from the "royal elite" to an actually fair and free world. I have no idea what the mechanism for that would end up being by the way.
So, whatya gonna do.
Very funny how so many here know so much about China when they've never visited. Bullshit on the communist control; if that's the case how do some of my friends who's families are business owners drive maseratis and Mercedes s-classes and have more money than most Americans can even dream of? And no, they're not communist officials, just do-good businessmen. Explain the 4 million millionaires in China, and growing everyday. The fact that there is even one proves that the country is only communist by name and you have no clue what you're talking about if you think otherwise. Economics major here as well. I thought China was a mess until I took a look myself and realized how ****in' deluded we are here in the states.
Take a trip and you'll realize how our deteriorating infrastructure, education system, social attitudes are actually quite a joke overseas.
Regardless about politics, I buy American first and foremost, but if the quality is good or I like the knife I buy from wherever.
Just a quick search...
http://www.telegraph.co.uk/news/wor...o-fight-terror-with-dozens-of-new-cities.html
"Many of the new cities and towns will reportedly be built by the Xinjiang Production and Construction Corps or XPCC - a state-run paramilitary organisation that controls large swathes of the western region, a sizeable agricultural empire and even its own university, courts and police force."
Now, these towns are to "fight terror" and "establish control of lawless regions" but it does show that the Chinese government has a bit more control than ours.
The main reason I turned to Chinese knives is that its very hard to find "made in USA" knives that use surgical steel.
BINGO. "Surgical steel" makes me laugh. That people buy into sch a BS marketing term just makes me shake my head in wonder.
I'll relinquish that point if you'll admit that their refusal may not have anything to do with the quality of the knives themselves.
Perhaps. Perhaps not. Too many Chinese knives have steel of dubious quality and heat treat. There's a reason it is often difficult to discern or determine the steel of so many Chinese made knives. Then there's the very real possibility of it being nothing but a lie when you can discover the steel claimed to be used in the product. Just part and parcel with their often encountered business practices.
So everybody see what's going on here? The only way for these folks to try to defeat me is....
That says much more about you than anyone else here.
Believe me, many here know exactly what's going on here as you've made that abundantly clear. It's not necessarily flattering to you though. Just a thought.
Anyone who makes the blanket statement "China-made knives are crap" isn't very knowledgeable about knives.
Why wouldn't people think that China-made knives are worthless pieces of trash ? I've read numerous times about cheap Chinese knock offs. Cheaply made knock offs seem to be China's forte. Perhaps China does make some decent knives. But it's their own fault for being known for producing complete garbage.
And that blanket statement is nothing compared to yours , bran. Good one 😐
Why do I now wonder if you have some sort of financial interest in Chinese made products?
Not that it's any of your business, but I own shares in the largest equity index fund on the planet. The underlying assets of the fund consist of the shares of thousands upon thousands of companies. And you can bet your sweet bippy that a bunch of those companies manufacture products in China.
Welcome to the global economy. No one says you have to like it. But to quote the Borg once again, resistance is futile. You WILL assimilate. (Or more accurately, you already have.)
Many people would think that, they just aren't very knowledgeable about knives since there are so many very good knives coming out of China at a wide variety of price points.
Yep. And Wolverine has already admitted that he doesn't own any Chinese-made knives, so we know he has no personal experience to speak from.
You've got me curious. To which brands do you refer ? I'd like to check them out.
No you wouldn't. I've already recommended companies whose products you should check out. What are you waiting for . . . an engraved invitation? Or are you resisting buying one because you're afraid people with actual experience like IP and Brancron and myself just might be right?
Personally, I prefer,
1. Handmade
2. Made in the USA
3. All others considered
I may couch that a bit if it were an antique collectible.
HaHa. Stop harassing IP and get to work. And don't give me this nonsense that you don't know where to look and you don't know what to do. You're just back to playing the deflection game is all. If you really want to find out if Chinese-made knives are as well-made as we say they are, there's only one way to go about it. Get one and see for yourself.
I would start with Kizer, personally. They have some fantastic deals in their lineup, fit and finish is very good and just all around well made. Reate and Stedemon are also excellent options.
On the lower end I would mostly recommend the products designed and marketed by American companies, knives like the Tenacious and Thermite, though there are far too many options to list at all comprehensively.
Wolverine doesn't need any help, IP. He's just pulling your chain. But it's nice of you to chime in anyway. :)
So there you go, Wolverine. Need to hear it from anybody else or do you think you know what to do now?
