- Sep 7, 2006
CPM-M4 is great but it will rust and stain like crazy. I'll take a stainless steel like M390 over that any day. But then I live near the sea... YMMV.
I'm guessing that when not testing and really paying attention closely that most steels are pretty darn close to the same thing. I've personally carried and used a few different steels with simular thin and sharp edges just as edc knives and truth is they all needed a sharpening after some good use. I really couldn't tell you nor did I notice if one really out did another. However, I have tested some of these same knives and easily could see a difference but that was all semi controled cutting and paying attention to what I was doing.Hi Sal,
Yup, Exactly.
I use as many different steels as I can, it's interesting how similar some of the steels really are in use, say at work.
Jim
I hope Mr.Osbourne doesn't mind me playing on his design...
I think this is how it should have looked coming out of the factory - Cleavers just aren't sexy enough
I'm very curious to put this through some beatings and see what M4 can do
from this...
to this...
Oh, I'm always learning from my knives and edges. Somedays I learn I prefer a coarse edge and then there are the other days I learn I prefer a polished edge.Truth is my needs do change depending on what I'm doing and I really notice what type of an edge is needed moreso than any difference between most of the better steel types. I'm kind of a retired steel snob. I've tried many different steels and really haven't been blown away by any of them for very long. Like most here already know you give up one thing to gain in another and for a edc knife what ever is lacking in the steel is going to show up sooner or later.
Any of you guys that have experience with CPM-M4 and have worked it hard, would you define it as stronger than 5160 as well as tougher? and if so, is there a stainless that compares relatively well? As I'm not willing to use a "super hard" steel for my knives if it can't be resharpened or it's going to break or have the edge chip under hard working conditions.... and I can't believe nobody shat on me for still using 440c I expected at least a laugh or two for sticking with it this long
Ted Ott's blade is wild -- it has a dumbell cross-section.
Wow, fantastic! Did you grind that cold, or did you anneal it and re heat-treat it? If you ground it cold, that must have taken a long time!
The difficulty the OP has here is that the best knife makers with skill in using the alternative steels he mentions, such as Phil Wilson, don't do choppers ... and those who do do "choppers" , are working solely with M4 ... such as the Osborne knife he already has ...
The thing with knives at this quality level is that it is all about the "knifemaker" and not the steel ... you would'nt be able to compare the Osborne knife to other steels unless someone like Osborne or Bradley were prepared to change tack and work with those steels to build a similar knife ... meaning that the knife had the benefit of a lot of testing to optomise the HT/HRC and grind for that given steel ...
If you had a good maker give his "best guess" as to putting a knife together in those other steels ... you might be "close" ... but the guys who can do such a job are unlikely to put their name to a knife which they have'nt had the chance to test ...
Personally if I can give an opinion based on having some great blades by those mentioned and a few others by top Smiths from Japan ... you don't really learn a lot about the steel from such great makers ... you learn more about the grind and the HT selection process and basically "their skill" to make a great knife ... the good makers can take an average steel and make a blade which will perform way beyond what you might otherwise expect ... Ankerson noticed this with his Phil Wilson blades when comparing steels ... the results if factored in would simply distort the overall picture when the other knives were factory mass produced blades ...
So if you want chopping knives which can give the Osborne knife a run for it's money in different steels you really need to look at specific custom makers ... and if done to a competition grind ... your own skills ... as competition blades can be warped if your technique is off ...
As others have said ... a lot is down to the "use" which then dictates "the knife" ... missing what you want to hit or catching stones if hitting near the soil ... these factors all change what type of grind works best ...
you guys are amazing... i can hardly keep up to the reading and cross referencing to even get my head around what I want to know. the case with me is close to what most of you are talking about... with the "missing and hitting stones if hitting near the soil" end of it. I don't do competitive cutting and I don't make my knives to be pretty, I just want a steel that gives me the best toughness and strength I can ask (of the steel... the HT, and geometry are my "problem") so to speak. but if I know one steel will hold up better to abuse than all others then that's what I need to use. so far as from what I can gather, the M4 is a pretty good choice if I'm willing to sacrafice a bit of edge holding to the others. much appreciated guys
