- Mar 31, 2016
that looks like a fair day's work there, peg
No kidding! Somebody pack in a cooler full of suds for when the trail became visible again?that looks like a fair day's work there, peg
Gee whiz! Overproof navy rum decanted into unbreakable mickey bottles were often joyfully-discovered ballast at the bottom of my 'work party' packs eons ago. Dilution with stream water thinned it into flavourful cold drinks and the alcohol was practical insurance against beaver fever bacteria.That was backcountry. Nobody packs 'suds' up there without a mule or pack horse. However the thinnest lightest 20 ounce water bottle ended up in my pack full of my favorite bourbon. No idea how it got in there () but it made 3 nights on the trail more bearable.
Great video.
Have to wonder why the top was wedged. That kerf should have been opening at the bottom and the saw falling free. If the bottom wasn't opening then it didn't need to be underbucked. And it might have opened if the top wasn't wedged.
Then there's the misaligned cut, no doubt from trying to match the bottom cut to the top cut instead of the other way around. Then he cuts 4" past the top cut.
Too many errors there to say which was most critical. Who was the sawyer in charge?
And when people say he "crossed his kerf" what are they referring to?
That's a big log and also looks to be of the Red Oak variety. Meaning there was considerable effort/work involved in sawing it up. Wonderful handle material for somebody were 16" not the standard 'bucking' length for timber at the limit of becoming 'too heavy'.This is what I meant:
Actually I meant that the undercut on the sawyers side was offset to the left of the top cut but somewhere in the middle of the log the undercut crossed to the right of the top cut. The saw was supported by the underbucker on the stable side of the log but was beneath the offset on the drop side. When the log dropped, it captured the saw, which had crossed over (under) from one side of the top kerf to the other.
I am still working on learning which are the best tools to find and buy to use on my plain tooth one man.
If any one has suggestions or recommendations from experience that would be greatly welcomed.
Only three basic tools needed to file a plain tooth saw -- jointer to make all the teeth the same length, file to sharpen each tooth, and a spider to measure the set of each tooth. A small hammer and an hand anvil (which can be any hammer head) to bend/set the teeth. You can make a jointer by cutting a kerf in a small board deep enough to hold a file perpendicular to the blade.
Discussion from crosscutsawyer.com: http://www.crosscutsawyer.com/viewtopic.php?f=21&t=683&hilit=Disston+964&start=10#p2954
The Simonds #342 combination jointer/raker gauge is an easy to use and versatile tool. You can use it to joint your plain tooth saw and later use it for lance tooth or champion saws. Instructions for use are on the web. You can make your own spider. Any small hammer can be used to set the teeth. A large rounded hammer face (un-handled) makes a fine anvil for setting. Good lighting and good files make your life easy.
A pair of tri-squares can show you the bumps and bends in your saw (hang it, handle off). A cast iron table saw top makes an adequate saw anvil. Some bumps will hammer out better on a softer wooden surface.
That looks nice.Oh and this is the wall hanger that sparked our initial conversation last week...
