I got email from Knifecenter telling me it was on back order and to expect it to ship 5-7 days, then i got email later saying that was a mistake and apologizing. Bummer lol.
KW has these right now, and for a great price.
Has anyone actually used their cruwear Millie yet? I'm curious as to how it sharpens, holds an edge etc? Fine or grainy edge?
Thank you for sharing your insight.I will have to experiment with this steel to find my sweet spot.This is the beauty of trying new steels as trial and error seems to help me find my personal preference when experimenting.This knife will be a sweet user..I usually run my Ingot Cruwear, Vascowear at around 400 grit. The CPM Cruwear, Z wear, and even 3V gets between 600 and 1000 grit depending on chores intended. For storage purposes I sharpen up knives generally higher as it seems to me, after 45 years but absolutely NO scientific studies that the higher grits lose sharpness at a lesser rate than lower/less polished grits. As I said, I have no evidence of this having any effect whatsoever. I generally clean my knives , dry ( leaving no skin oil or salt on knife) and either Renn wax, or Silicone oil ( 100% pure liquid from A.G.Russell). I do this to eliminate as much as possible corrosion being a source of dulling on the edge.
The steel(s) can take much higher polish but I don't really see much cutting difference with the typical EDC chores of mine. I enjoy the extra bite of the lower grit on the plastics , cloths and things like bandage material ( for Finn the mastiff). On cardboard and paper the higher grits seem to hold up better so if I was going to break down a lot of boxes, or use the blade on wood I'd go up in grit to over 1000-2000 grit. All numbers are with light Chrome oxide strop.I have a habit of always checking for wire edges or Burrs as the steels in this category are tough and can hold burrs well too if not careful.
These steels, Vascowear/Cruwear and descendants can be very aggressive slicers and pretty tough with the right geometry. The Cruwear/Vascowear/Zwear, etc. steels are less prone to losing properties from power sharpening if done properly of course. The tungsten protects them somewhat, with a high tempering temp. and when someone claims "power sharpening overheated my knife causing lower performance" (which I haven't heard with this steel yet) my first suspicion is to think that there is a wire edge or burr present but being pretty tough, is still there despite attempts to get rid of it. Always check if you have lower performance. Also keep in mind this steel isn't designed to have 10V/A11 or S90V/S110V abrasive wear resistance. It's not in it's job description.
Also note the "sweet spot" for me will be different for you as we likely have different uses and needs. Experiment until you find the angle, thickness, and grit that fits your needs best. This goes for all steels naturally, not just Cruwear.
Joe
Joe
I appreciate Spyderco making a larger batch, and trickling them out verses one shot and they are all gone.
I'm pretty sure my odds to get a Cruware increased. As an enthusiast I am willing to invest the required time seeking said desired model. Not sure if this was their intent, as to sell all the stock in one shot is good for them, but still thanks, it helped on my end.
