- May 7, 2012
With Nathan & Lorien's permission, text (edited out first person so it doesn't sound like I am saying it or quoted where necessary) and pictures, I wanted to create a thread here, primarily for reference. Right now it's a condensed kinda WIP thread after the dividing line saving a reader from who knows how many pages in the other EDC thread there are as of today providing just the critical info.
Current info here:
The 3" EDC was designed as a collaboration with Lorien Arnold. It is a well made, no frills, high performance, small utility knife. The steel is Crucible CPM 3V at HRC 61-62 with a fully optimized heat treat with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V this hard and thin, it is gonna blow your mind.
This steel with this heat treat will support a fine edge, so this was taken down to .015" before sharpening (though I'm leaving some additional meat in the tip) and it was sharpened 18 degrees per side. This is relatively acute and it cuts very well, but is durable. They're also lightly hand ground after machining to give it a slight convex grind.
The primary grinds on these are more narrow than the Field Knife. They are quite "slicey"
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon. It's thin behind the edge. It is a hard working cutting tool, a tradesman's knife and small woods knife.
It's very light weight.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. Despite its compact size it fills the hand and allows extended hard work without hand fatigue. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of 1/8 3V with a heat treat that has been optimized to maximize edge stability in rough use (see video). Despite being relatively thin it is very durable.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Specs:
3V, 61-62 HRC, .135 thick at ricasso (a hair over 1/8")
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Grippy 3D machined scales in micarta or G10
Black oxide treated 18-8 stainless steel fasteners
Hidden lanyard
Choice of vertical or horizontal Kydex sheath made by Dan Crotts of Dozier Knives. If you want one of both sheaths, an extra sheath is $50.
Be aware the horizontal sheath has very high retention. You can't remove the knife by pulling straight back, you have to tilt it up at the same time. See video. If you want something that's easy to get in and out of you should choose the vertical pouch sheath.
$215 in canvas micarta, natural or black
$225 in black or OD green G10
$235 in maroon linen micarta, camo micarta or black/blue G10
Shipping in the USA is $10.
Includes a good kydex sheath, choose vertical or horizontal. An extra sheath is $50
Here is the development info as it was shared in chronological order:
News broke on June 17th, 2016 with an announcement by Lorien:
"Nate and I have been working on a fixed blade EDC knife for your average beer swillin', knuckle draggin' working man, and it will be equally useful for metrosexuals, hipsters, uber drivers and punk kids. We don't want to leave anyone out
On June 19th, Lorien posted:
June 28th, yet another teaser, this time from Nathan.
Followed up by this pic from Lorien:
"here's a photo I found of one of the models I made;"
And this::
And this...:
Nathan followed up with:
"It'll be D3V, but I've bumped the hardness to HRC 62 trading off some toughness for wear resistance. Similar animal, but tweaked for the smaller knife, same as the Field Knives.
Both thickness and primary grind angle are thinned down some. It will be .135", just a hair over 1/8"."
And replied to chiral.grolim's question:
"Wanted to add, any plans for pushing the edge geometry on this one below 0.020 at the shoulder, maybe even as low as 0.010"?"
With:
" considered that, and I may grind a few really thin like that, but the concept for this knife is a rough and ready user for a trades person and a convenient woods knife. Cut and strip wire, deburr PVC pipe, cut the bump off the end of a cut 2X4 etc. I use stuff like this in the shop and I think nothing of shaving a little metal off a fixture etc. It's convenient to have a tool that doesn't need any special care to keep from damaging it.
I love a really thin knife, and I'll make some, but this guy is going to be pretty middle-of-the-road.
edit to add: I will grind a few extra thin, just for you"
June 30th brought more pics provided by Lorien
And this little tidbit:
"the EDC is designed to allow for cord wrapping, or straight up nothing, if you need to shed some weight."
Lorien on July 6th:
"From Nathan;
I got the first of the scales milled today. This is the blade I'm sending to the sheath maker, it hasn't been heat treated or tumbled so it's a little shiny and unfinished, but the pictures give a good idea what the finished knife will look like."
Nathan posted in this Thread on August 2nd:
Specs:
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Hidden lanyard
August 3rd:
Two videos.
First is Sheath information:
[video=youtube;HiG_KqF06KY]https://www.youtube.com/watch?v=HiG_KqF06KY[/video]
Second is durability testing!
[video=youtube;zC_-PIFw-KA]https://www.youtube.com/watch?v=zC_-PIFw-KA[/video]
August 3rd:
This steel with this heat treat will support a fine edge, so this was taken down to .015" before sharpening (though I'm leaving some additional meat in the tip now) and it was sharpened 18 degrees per side. This is relatively acute and it cuts very well, but is durable. They're also lightly hand ground after machining to give it a slight convex grind.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. Despite its compact size it fills the hand and allows extended hard work without hand cramps. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of 1/8 3V with a heat treat that has been optimized to maximize edge stability in rough use (see video). Despite being relatively thin it is reasonably durable.
Specs:
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Hidden lanyard
Be aware the horizontal sheath has very high retention. You can not remove the knife by pulling straight back, you have to tilt it up at the same time. If you want something that's easy to get in and out of you should choose the vertical pouch sheath.
These are all field grade, as machined and stonewashed with tool and grind marks.
$215 in micarta, black or brown
$225 in black G10
I think that will be the end of this one, unless we see some more handle material.
Hope this has been helpful!
Current info here:
Specs:
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Hidden lanyard
And this::
And this...:
With:
Lorien on July 6th:
"From Nathan;
Specs:
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Hidden lanyard
August 3rd:
Two videos.
August 3rd:
Specs:
Total length 7.5
Blade length 3.2
Weight 4.8 oz
Edge angle 18 DPS
.020" BTE
Hidden lanyard
$225 in black G10
