Daisy Cutter Protoype
OK Vec you sold me that this will be a excellent weapon. How will it do as a TOOL? Will this piece of gear do the double duty?
Dose it chop wood and split it?
Will the edge hold up to softer metals (escape/rescue duty)?
Can I use it to breach walls of modern materials (drywall and studs/ cinder block/ stucco) and Adobe or hard mud construction?
Will it slice and pry, duty more solders will need to preform than CQB?
Will this weapon work in a more mundane roll as a survival tool. Not as a rock is a hammer or a knife can be a screw driver in a pinch, will it shine? should I be ready to retire the rest of the collection and replace them with the Daisy Cutter for camp, chores and car/truck carry?:eek::D:thumbup:
I think I know but would like your impressions (the way you do).;)
it will do double duty, but the Melee Handle is made for gross movements mostly, like when you are swinging for your life. - the middle of the handle is along the axis of the balance point, so it will be very good at small detail work in utility i think. the bend at the butt of the handle is angled to stay out of the way when you smash with the poll as you grip the handle in the center, but that isn't good technique IMHO for utility purposes - great in combatives though, but i don't see hyper-extending one's wrist that way in combat - i'd hate to get licked in the nose with the pointy end of the handle in close quarters - casually hit Prey in that nerve beneath the nose with the butt of this thing, and you will be in a position to own him.
i want to make a Utility Handle for the Daisy Cutter head, and ultimately make a Hybrid Handle for it, which will be longer than the Melee Handle, but use the same angle technologies that make the Melee Version of the Daisy Cutter so superior for combatives.
i'd also like to sell the head alone, so folks could make their own handles and tools for it. we'll see what develops.
i designed the Daisy Cutter with combatives in mind - but as a former grunt i wanted to have something that was good for utility too. the SF guys that have looked at the Daisy Cutter are going wild so far, because there is evidently a viral thought pattern amongst them that is pro-tomahawk these days - we shall have to see what develops there, that's out of my hands beyond providing a tool that i would carry, if i were them.
....well, in tests so far with the protoypes, which are inferior to what the finished product will be, they indicate that calculations of the head design are consistent with actual performance. (that means it is a splitting mother-effer, fellow-babies.)
splitting is where proper conventional tomahawks typically suck compared to hatchets, but you are normally penalized with weight and crappy balance if you go the hatchet route; the head weight of the Daisy Cutter is 16.1 ounces, which is light enough and leveraged for effect with the handle to be a deadly weapon, but heavy enough to split better than a Cold Steel Rifleman's head (which weighs twice as much approximately) while being barely heavier than my favorite stock tomahawk, the Cold Steel Trail Hawk head (which typically weighs about 15 ounces, unhafted).
the cross-section of the bit on the Daisy Cutter is wedge-like, but the approach angles make it slice like a thinner edge, while allowing you to split average stationary logs with it with one shot, similar to a splitting maul, while the grooves reduce friction when passing through the hard stuff.
one of my biggest concerns is that i may have made too many of the fullers/grooves actually, for the typical user, because folks will tend to use too much force with the Daisy Cutter when a little force will do, and they might be slamming the edge into the rock beneath the log as it flies out of the way.
this ain't no overpriced camp hatchet.
tutorials will probably be important. :cool:
i do a lot with extra thick and robust edges in some of my designs, then make the media approach the edge at an angle, so that the edge acts like a thinner blade. with the Daisy Cutter i took this concept a step further and made an unconventional handle ( - the Melee Handle design concept) that allows the user to kind of go on "Auto Pilot" so the operator is just looking for zombies to smack, and the ergonmoics and orientation of the blades optimize penetration and impact, and less mental effort is spent with fine target indexing.
i'd be really surprised if the Daisy Cutter wasn't made illegal in some places eventually, once folks capture the essence of how it is used; fast as a baton, with the slice of a khukri and the pentration of a spike.
plus the Melee Handle itself is a weapon, ...forget the head, that's just going to be the warning in skilled hands.
i reckon so.
i've made similar edge geometries in butter-soft 304 Stainless that could work all day on sheet metal, so i am confident that this will do much better.
we are looking at 5160 or 1075 that is zone tempered for initial production, plus the physical attributes of the head and handle will give the head more durability than one would expect because of the edge configurations and approach angles.
it's very exciting to see this family of designs being produced much earlier than i thought they would be. God Bless TOPS, is all i gotta say.
both these steels and the edge profiles are easy to fix in the field too, compared to others that i have used.
the Daisy Cutters will be covered by Equinox Coronado with our Happiness Guarantee anyways, if we sell them (vice TOPS selling them) so that is a lot of insurance built into a purpose-built War Hawk if ya ask me.... YMMV.
yep.
the Bomb Poll and handle design is going to make those things surprisingly easy - i can't overemphasize that enough - the bit end will do well too - but i purposefully built the Bomb Poll to tear through stuff just like that, especially if you have to leave the room without using the door!
accessories that you can make or buy from us will make it better though.
think about putting a big spike attachment overlooking that Bomb Poll, for instance - or an adze or E-tool attachment. i am going to make a ballistic plate for myself that can double as a shovel, for instance - good for EOD purposes when ya gotta dig out a dud JDAM in the middle of a ville....:cool:
i don't want to make tools for it when there are things laying about that the end user can make themselves - it makes a less-expensive tool, and a smarter user that way - any grunt with an E-tool could probably cannibalize the head off an E-tool and adapt it to the Daisy Cutter for instance, especially with some construction hints....
it's definitely a slicer, despite how wedge-like the edge is, for reasons mentioned above.
it's got a lot of pry in it too, but i am looking at changing the Melle Handle slightly to accept "force batons" that will make the handle extremely tough compared to the stock handle - the final mterials will be pretty gnarly strength-wise IMHO, but a Marine can destroy anything in my experience amongst them (it was always amusing until i got tasked with making them and their counterparts in the other services tools - doh! - hahaha!) - so i'd like to give the grunts some more options.
....maybe replaced by the Utility Version of the handle, brother. we shall see!
it should "shine" in both variants, but i expect that the Utility Handle will be what most folks prefer over the Melee version.
i wouldn't personally carry or design something that was too much weapon and not enough tool. this will do (for me, at least).
myself, i get kind of tired of the same tools in the field - it's too much like eating the same thing for months, which i have had to do.
i'll always cherish my custom Swenson Sabretooth Knife and my leather-handled Estwing Hatchet, etc. - BUT if i was going out the door and never coming back, i'd grab the Daisy Cutter and two ECO Hawks and never regret it probably - because they are designed by me for my purposes, where no other good tools are - but to me there is more to tools and weapons than utility, especially since we are survivors, and the more advanced amongst us can make do with anything.
i just did a little post in the Wilderness Forum here, with pics of some of the stuff i carried in the Dez last week....
hopefully, all that garbage i just puked out helps a little, brother. it is intriguing that something that is so straight-forward in one's hands, as i contend that the Daisy Cutter is, requires so many words to describe....
the Daisy Cutter is a work in progress still, but it has impressed me so far.
if it sucked, i wouldn't be working on it.
HTH.
vec
vec
So you wouldn't take a knife? Why two ecos, one for backup?
I might have missed it but what is the price for a "DC" gonna be
I have to start saving early....if it in my reach
Ecos is designed to function as a Knife when used with out a handle.
Granted I only got mine yesterday so I've not been able to really wring it out but it's not a knife. Sure it could be pressed into service as a knife if that's all you had but I would regret walking out the door without a proper knife.
You can definitely use it as a knife it just wouldn't be my preference. I'm just thinking that it's not going to be as comfortable as a regular knife to use for extended periods of time but again I just got it. Maybe it'll surprise me. For me, and my hands, the "grip" isn't as comfy as say a full fat handled bushcraft knife.
The reason I got it was to have a chopper that I can wear on my belt. I'm going to use it in conjunction with a SAK on easy going, warm, dayhikes in the summer time when I'm not carrying a pack to hold my GB mini. Most of the hikes I go on are heavily traveled and some are even within city limits so a covert chopper is just the ticket. Serious hikes I would opt for a hatchet/hawk together with a more substantial knife like my Koster bushcraft. Man, hang out with Vec enough and you start to ramble.:D:p
serves ya right. :D:thumbup:
to answer your original question, brother; - the ECO is a knife, a really good one, when you hone it up a little that is - the factory edge is what i decided to go with to be good enough for a knife, but (perhaps) a bit on the durable side in case a user chose to use it primarily as a hawk.
- i find that when i have the ECO on a haft, i tend to leave it on mine as much as possible, because it is a really good one-handed draw knife in that configuration. not much ya can't do with an ECO on a haft.
thin down the edge if ya like, and do a hasty wrap around the middle of the ECO while using it strictly as a knife, and you might develop a serious issue with carrying some other knives.
it just works.
two ECOs allow the user to do a variety of special weapons with the ECOs, hafted or unhafted - that's why i like to have two - plus i can modify the two differently from one anohter, like Scandi grinding one of the Tanto/Spikes, while leaving the other ECO in a standard condition, or serrating it, plus other mods...
lots of options, that's what i want, and at barely 7 ounces, one extra ECO won't hurt me... especially when i am using it as a shuriken... as i charge in to finish the job on some bastard... (i've always wanted to pull one of these out of a crrok's skull as i said "Hey! Leggo my ECO!" :cool: )
the ECO was born to mod. it's a Thinking Man's Tool.
nuff said, i reckon.
vec
i don't know how much it will be yet.
if ya like, contact my Erica and she will put you on the Wish List, brother - the more folks we have contacts with to offer first dibs too, the cheaper it should be, if we wind up selling it.
HTH.
vec
BTTT, just because I want one of these when the time for production comes.
They look too badass to not have one!!;)
Vec, how is the prototype work going with these?
they work. :cool::thumbup:
a short blurb to highlight what's going on;
i can only speak about my personal viewpoints, because i am the only one that has tested them to any degree - i've had some surprises actually so far - good ones; some brethren that got to hold them up at our desert getaway a few months ago all wanted one immediately, so i am hoping that is a good sign. ...when i get the tool accessories for them, i think folks who aren't real hawkers or hatchet men will sit up and curse my name, when they start lusting ...:D:thumbup:...
i made a solid handle (on sort of a whim) that i call the Daisy Cutter Breacher - sort of an over-the-top (i thought) design, and it turned out it wasn't too heavy at all, but really wanted to kick some ass and take names. It should be interesting to see what the services think of it, and its offshoots.
I really like the hollow handles, which were the original idea, which are also tough, but with them i want to make some compartments inside, and make the handle removeable - i might do that with the solid handle too - there is a lot of work to do still.
fast prototyping ain't for whooses.
the head took me aback, in how well it worked for me - i wanted something gravitating towards the Battle Axe/Forest Axe weight-ratios that most folks like, while retaining as much of the proper hawk physics as i could.
TOPS seemed to be pleased with the reviews that the DC Breacher got at Blade earlier this month, but we have been playing phone tag as they and we are very busy currently, so i am not sure what their plans are. - i'd like to move to a utility-centric handle option, and refine the Melee style handle (which is identical in profile in the Melee and Breacher handle, but different internally) some more, but she is good to go now. - economic realities will dictate what happens in the short term - i barely got the Melee handle out with my last mold materials, so we are a little dry right now....
if i can get some investment in the Daisies, i will be able to get more materials and big tools (lathes and mills), so we can move on to some great things to share with our investors - particularly Daisy Cutter accessories.
TOPS really is tops, in my book.
my ideas work, because i have a lot of good virtual tools and a bit of experience in the field, but if it hadn't been for Mister Fuller and his team, none of this would've happened, at least not so quickly. - we are fortunate being mostly all from a military background, where we grok each other quickly compared to a lot of other manufacturers that i have worked with, and that has been essential in building the trust that i have with my designs that i share with TOPS;
we have a long way to go, but the Daisy Cutter and the ECOs have really been a dream come true for me - not just as a manufacturer, but especially as a guy that has always wished he could have just what i wanted in the field - and now i do.
if other brothers appreciate the tools, excellent.
my YouTube channel will feature the Daisy Cutter in bits, soon - it should still be linked in my signature line. the Daiies wil really shine as folks see it in use - i'v egot some footage of the proto spinning in my hands and being stopped all lined up and facing the correct way - stuff that is demandinf to do with other hawks and handles, especially under stress - the Melee handle does a lot of the work for me... my hands are actually kind of big and klutzy IMHO... so it is noce to have something that moves like it is part of me, without months of use and familarity being necessary. - i think troops will appreciate that.
anyways, i hope that we can help everyone out that wants one, and that we can improve with their needed feedback.
sorry i don't have something firmer to offer - it's going to be, i just don't know how it is going to be, at the moment. - typical manufacturing process...:o:thumbup:
HTH.
vec
So, you're going to send me one for testing and review, right?
i am very bribeable, if that's what you mean, brother ...:D:thumbup:
TOPS just bent my ear for a bit on the phone - looks like the Daisy Cutter will have a bright future.
time will tell.
vec
Wondering how this project is going, Vec. Anything new you'd like to share with us? :)
it's going very promisingly, if that is a word. LOL.
too early for specifics, brother - but I am waiting for a new mill and a few other tools and materials to arrive for my new prototype shop.
after i get all that garbage set up, that will allow me to produce a lot of things, including absolute control over the Daisy Cutter Project.
the fearful suspense of the wait for the goodies is killin' me.
the Daisy Cutter is going to happen, what i am anxious about is getting new composite handles out for the ATAX and ECO Hawk, and for conventional tomahawk heads - especially for the benefit of the Investors that have been waiting very patiently.
i intend to do a Hawk Project Update vlog on YouTube as things get going. - so folks can know where they are in the cue, make informed decisions about alternate designs plans, etc.
the new little mill and the other stuff is meant to buy me some time (while allowing me to make some serious goodies, fast) ...before buying a new shop location, etc., and progressing on to really advanced stuff, and new rifles and such.
i can't wait to make my rifle designs... but that's another forum.... :cool:
i am just amazed that a temporary tabletop business exploded in my face like this.
this business has really introduced us to some unbelieveably great people too.
wish us luck,brethren.
thanks for asking, brother burke!
i will be hurrying up and waiting here.
vec
More pictures brother Vec!!!
I contacted erica as well about getting on the list. Another question, any chance of a permanently attached model similar to your original hawks?
Keep up the work, that thing is BEAUTIFUL!!!
