- Sep 2, 2008
Very good point :thumbup:
Ill be putting in for a couple permits to hike Mt. Whitney this summer. Probably going to be in August during a weekday. Anyone up for it? Probably look at staying at least two nights in the area, one in Portal camp at least the night before and one the day after because will be to exhausted to drive home. Its a lottery so not sure if Ill get any. Start training soon if anyone is thinking about going.
Finally picked up HF 1x30"Now need to order belts. I've read that some folks can't get the 1x30 to run scotchbrite belts. Any of you guys actually used the scotchbrite belts on a HF 1x30?
1x30 ScotchBrite are available at TruGrit, but may not work for you.
My 1x30 is a HF special and won't even start with a ScotchBrite belt installed.
My HF 1x30 also chokes with Scotch-Brite belts. It's hard to see how reflective your blades are, but the ones I've done with a fine grit gives a similar finish to yours.
I've been seeing people say that, I don't have a HF but a grizzly 1x30, but I'm thinking it's about the same quality. What's the issue, too tight a belt?
Scotchbrite belts are the way to go for a brushed/satin finish. I use them all the time. The final finish is done with a fine belt loaded with compound.
If the motor on your sander is small, they probably won't work as has been stated already.
Scott
I think it's not that the belt is too tight - it goes onto the wheels with less work than some belts. I think it's that it takes too much work to flex it around the wheels for that poor little 1/3 HP motor (if it's really even that strong).
Even refinishing a knife against the platen (say a flat ground knife) is going to chatter on the cheapo 1x30s. To save you some money and headache, i'll also tell you that the SB belts will not work on the cheap HF sanders either, they're too thick and you will just hear the motor run.
I'm looking to backpack or hike president's day weekend...anyone game?
From what I remember reading (have to find the actual threads again) the 1/3 hp motor couldn't turn the relatively stiffer scotchbrite belts. It's just too underpowered to run with those belts on. I'll dig up the threads again.
No specific plan yet. Getting out for a night or two would be nice, but I haven't really thought of a destination yet. I'll post some options later, anyone who's interested feel free to post options as well :thumbup:
