Actually, it showed that liner locks and framelocks are easily capable of supporting far more weight than that. Certainly, either one can support far more weight than the slip joints that have been capably serving for years.
As an aside, my pockets are fine. The 0566 isn't shredding them, as the link suggests it should.
Yeah, so, what's up with his claims that none of the linerlocks he tried could support more than 100 lbs?
There is NO spring tension applying closing pressure, your thoughts and feelings on the matter do not negate this fact.
Actually, there is. What do you think keeps the detent ball kept in place? The lock (AKA leaf spring) applies spring tension to help keep the blade closed. I understand the point you're driving at, but the statement you make is false.
Technically, hardheart is correct and your statement supports him. The ball-detent holds the blade in place via friction just as a ball-detent keeps a friction-folder blade in place, spring-pressure (be it a lock-bar or handle-scales) holds the ball in place but does NOT hold the blade closed via direct spring-tension on the blade or tang. However, the point is moot since as soon as the tang attempts to overcome the detent, the leaf-spring or scales apply spring-tension to keep the ball in place if they are not doing so already.
In the AXIS-lock and CBBL, the springs continually put pressure on the lockbar/ball to move it forward onto the tang. Since the pressure is continuous, one could argue that indirect spring-tension keeps the blade closed. *shrug*
As blade man stated, the Axis/cbbl does not use direct spring pressure to hold the blade closed just like the liner/frame lock does not use direct pressure to hold the blade closed. The idea is identical, though. The only difference is a liner lock uses a large, stout spring against a small ball bearing for resistance while axis cbbl uses a small, thin (omega) spring against a large, robust ball bearing. The pressure does not have to be direct to provide leverage and make it work. Your car's spring dont have to be attached directly to the wheel to work. Same thing.
Neither lock uses spring tension to keep the knife closed, or you are referring to detent ball?I know the point he was making, I was just pointing out that his statement was incorrect, frame locks and liner locks DO use spring tension.
if you check forums and sites like yahoo answers bunch of people can't even disengage liner locks, because they do not know it's there.
P.S. Modern marketing is scientific, and it keeps up with science(neuro, human behavior) much better than the knife industryIt's rather naive to think you can be completely free of its influence.
...(maybe even all types?)...
Chiral, now youre arguing for the sake of arguing. Are you really saying that if you were to set the detent ball to fully engage into the detent hole and bend the liner to apply a much greater force on the detent and blade that it would still not provide ample force to retain the blade well. Are you nuts? Seriously, thats a pretty asinine suggestion. Have you taken a knife apart before and played with adjusting the size of the detent hole and the force applied to the lock bar. I have, several times. And i assure you it is very easy to make it not only retain the blade strongly, but make it EXTREMELY DIFFICULT to open without touching the pivot.
Again, this is all a moot point anyway because this is proving (again) that your entire argument is with the execution/adjustment in the liner lock and not with the actually the design itself.
