yes the knife and goodies are identical, the engraving is different. Some people like a clean knife and some know the heritage of Mr DP
I bet cost was one reason.
I do not mean to diminish the great qualities of D2 but, yes, I have read that S30V is a relatively expensive steel.Why S30V is a more expensive metal I take it then?
I seem to remember seeing something before, but could not find it. About the multi-tool/adjustment tool, will there be a 'sheath' or slip cover for it. I imagine it could do some serious pocket damage. Also I've looked for dimensions for it, any body have any ideas?
On a different but related note, if anyone needs some good reads this winter, RYP's books are awesome. So far I have read License to Kill, Hunter Hammer and Heaven, and Come Back Alive, all good reads. Just waiting for the others to come through the library.
This is taken from Benchmade's website. It is a fairly good description of both steels. If Benchmade is to be considered a credible source, and they are IMHO, then I think it is clear why D2 was chosen as the steel for this "hard use" folder.
S30V: An American made and developed premium grade stainless steel created especially for knives. It is a powder made steel with a uniform carbide distribution and clean steel properties. As a blade material it offers excellent corrosion resistance and superb edge qualities.
D2: An air-hardened tool steel, which offers good corrosion resistance and excellent mileage in wear resistance. A good choice for hard use applications.
Here's the link to the page where I found this info. Tons of good knowledge there.
http://www.benchmade.com/about_knives/our_blades.asp
that LE Mr. DP tool is godly, i am guessing there will only be 250 of those as well?
yup thats right. but the regular production gets this guy:
Hmm so they air harden their D2 as their "heat treat" or "Cold treat" like CS does?
It does seem as if S30V is a superior steel, but obviously it's more expensive.
What kind of heat treatment is this HEST/F getting? Everyone said the heat treatment is what brings the D2 up to a superior level.
I'm sure the guys at ESEE arent skimping either way.
Good point. I should point out that a lot of high end knives are made for a market and not a use.
Like "law enforcement" knives or "military" knives" or even "tactical" knives (WTF is a "tactical" knife anyways??")
The HEST is made for a specific application. Cutting... and long, hard, brutal use away from civilization, sharpeners and repair places.
For example I will "blood" my HEST folder on my upcoming trip behind enemy lines in Burma. Conditions will be tropical, mud, extreme humidity etc etc. It will be my only personal blade (HEST fixed for the commanders of course) and it can't fail, be too heavy or get finicky when used for eating, surgery, camp building, cutting etc etc. I don't want it to glint, break, get dull or get lost...and I need to be open in my hand and locked if and when I need it in a pinch.
So I just want my stuff to work.
D2 is highly resistent to staining but we coat the HEST blade to not only eliminate that problem but in the case of the First Run actually harden the blade beyond its normal specs. The Mil Spec coating is designed to seal the steel and lower the visual profile.
