It really doesn't bother me but the ball detent on mine is really strong, strongest on any folder I have ever handled. To the point where anyone I've handed it too fails to open it one handed. BUT, it is starting to wear in and my lock is failing less (but still fails).
I'd also like to say, that while it's good to know if I want to have my issues fixed or return the knife for a full refund, as an international customer, between the change in exchange rate and shipping costs, I'd be out quite a bit of money. I really do like the design of the knife, I just find it disappointing that a $200plus knife has so many QC issues straight out of the box. It is by far the most expensive folder I have ever owned, the rest of my collection ranges from $10 to $100 and I've never had issues with any of them new. I've only had one other lock failure, and that was on a POS Stanley folder, after 3 years of HARD use on construction sites.
Really? Well even sober, this is still the hardest to open knife I have ever owned. I did no personal insults, but to judge all Lion Steel knives by one example is not fair, and I apologized to Gianni for that and edited out my sweeping generalizations. But unless you have actually tried to open THIS ONE, you don't really know how rough it is. While my thumb heals, I will continue to work the action with both hands and see if it smooths out.
all that brass reminds me of those old people who buy gold or champagne colored cars with fake convertible tops and gold emblems and trim bleech
but i would take your knife over a hest folder simple because i know its gonna work 100% of the time and it doesnt have someones name on the blade..
Apologies are not necessary. Maybe you are right that knife is hard to open.
A simple test let you understand if it is only a knife problem or also a way of keep it while you are opening it.
Try to open the knife with the left hand, in this way you will not push the liner. Of course you have to consider that you are not used to open the knife with left hand (I suppose, sorry) but it let you understand if it is only a knife problem.
This has worked on some of my frame locks. Im still waiting on my LE. Get a bottle of REM oil pump spray. Shake it well to mix the Teflon. Spray the whole knife down. It will not hurt the G10 open and close 20-30 times to work the Teflon in the joints. Put the knife in a ziplock bag in open position for 24 hours to keep dust off of it and to allow the Teflon to cure on the blade. Try it won't hurt anything.I have been working it with two hands, as my thumb is blistered and sore from this thing. Yes, I can keep my finger off the liner. Believe it or not, I probably own over 1,000 knives. Maybe 100 folders. This one is too hard to open for me. I am 63 years old and remember when the only one-hand opening knives were switchblades. We used to attach thumb studs to Buck Folding Hunters to make them one hand openers. Then companies started making them that way. Since ease of opening is only one parameter, in a week I will do a full test and review. I hope it smooths out some by then.
Just a thought but have you checked to see if when you use the tool to adjust the pivot your actually loosening it and not just turning the whole thing? Might have to use the tool on it's side and the appropriate size allen/torx on the other. From what you've posted it's hard to imagine it's just the detent that is causing it to open that hard.
Mine was stiff and made my thumb sore as well but part of that was me playing around with the knife all weekend long after it first arrived. Since then it's gotten much easier to open though still a stronger detent than about any other knife I own. Not really an issue as I'd rather it be a little tight and wear in as I use it.
You sure about that?![]()
