Was a bit pressed for time last night, but I was able to start a testing series. I ran four of my favourite knives through my usual sharpening process on the Kalamazoo, and tested them within a few minutes of coming off the belts. The progression used was all Trizact for abrasives, A65, A16, A6, A3, followed by 1u Boron Carbide on a SurgiSharp leather belt, and .5u Chromium Oxide on a SurgiSharp belt. The edge is my normal working edge, and will shave armhair cleanly and easily with all four knives, and if I'm careful pass a low-level HHT. I can do somewhat better on the belts if I take more time, but I wanted to try my "normal" edge out and see how it looked.
Northstar EDC (3V steel, same knife tested in the previous series)
#1 = 86.0
#2 = 82.4
#3 = 86.2
AVG = 84.9
Spyderco Paramilitary 2 (same knife tested in the previous series)
#1 = 82.2
#2 = 81.1
#3 = 86.6
AVG = 83.3
BRKT Mini Canadian (A2 steel)
#1 = 108.2
#2 = 108.1
#3 = 109.2
AVG = 108.5
BRKT Saex Prototype (CPM-D2 steel)
#1 = 109.6 - Discarded this number, see more below
#2 = 123.4
#3 = 118.9
#4 = 121.7
AVG = 121.3
While I was testing the Seax, I noticed something interesting. I used up the media I had in the cup I use for "sifting" in the shot to the top cup on the test unit from the Mini Canadian test, and had to go to one of the little storage containers for a bit more. It took me perhaps ten seconds to reach for more mass, and in that time, the tester dropped on its own! Since I was not entirely sure what I had done there, I discarded that data point from my calculations, and completed the rest of the test series as planned. Since this struck me as something rather interesting, once I'd completed the test battery, I came back and made another pass at it. For this test, I chose the Seax (since it had displayed it once before already) and I chose a weight of 111 grams (since 111 grams is approximately 10 grams below the weight needed to cause a prompt media failure, according to the previous tests). My method for this test was to very, very carefully place the weight cup on top of the ram platform, then move my hand back to start a stop watch, and record when the ram head dropped.
The results of four tests are as follows:
7.3 seconds to cut
3.5 seconds to cut
4.2 seconds to cut
1.1 seconds to cut
I will have to play with this a bit more, I was not expecting to see that! I will also double-check my instrument again, with regard to ram mass. I am absolutely sure that my lock screw was fully disengaged for those tests. I also note that there was a reasonably steady downward trend in the time-to-cut, with no change in mass on the ram, or method of testing, that I have no idea of the cause for. I will play with this one more, I think. Would someone with a decent microscope like to give this a try, and see how it looks under magnification?
Finally upgraded to one of my good notebooks!
