Just curious Jim but are those edges what you'd call "Air Bleeding Sharp?":thumbup:
I think....
Someone using an EdgePro, with the proper stones, tapes, and strops, and a light enough touch, (perhaps it will need to be a small woman to do this...) will be able to produce an edge that will cut its way into the 4th dimension! :thumbup:
Stitchawl
Just got my edgepro a couple of days ago. I'm getting close to Ankerson but need a bit more practice. The polish is unbelievable. I've found I have to raise the angle up just a bit when going to the polishing tapes. Anyone else?
You do need to take into consideration the thickness of the tape blanks as compared with the thickness of the stones. I even created some special blanks to hold strops, adding several layers of leather under the strop to match the height of the stones.
I also found I got a MUCH better polish using a LOT of water with the tapes. I squirt them down between every stroke, and for the final few strokes add no pressure other than the weight of the stone arm. Using a good leather stropping leather as the very final step creates a mirrored finish you could use for the next Hubble telescope!
Stitchawl
I solved that problem by buying some Chosera water stones (1k, 3k, 5k and 10k) that are made for the EdgePro machine.
/dusty
Got them from Chefknivestogo.com... they carry a full complement of EdgePro products. Also Jendeindustries.com sells even more EdgePro products.
Hope this helps.
/dusty
I have not gone back to the instruction video to check but I am almost positive the he says NOT to wet the tapes??
I have been using mine dry without any problems but may check out the stones for polishing as well, they sound like a good idea
