You're telling me! I have a nifty little BM 940 Osborne that I reprofiled to approx. 30 degrees and have sharpened it with my Sharpmaker (diamond rods included) so many time in the past 6 months that it's getting a barely discernable recurve - because I can't get the beginning of the cutting edge on the rods due to the thumbstuds.![]()
I just wanted to post this and thank Knifenut for enlightening me to his opinions (and facts). I have never considered the change in angle as the stones wear as a limitation of the EP!
The precise bevel look nice but in use tend to show the most wear and sometimes even small chipping, something I quickly found out with one of my CPM-D2 blades.
This brings me back to my original point. If he actually used one, he would know this is not an issue.
I'm still curious about this statement you made, as it is something I haven't seen. If this really were an issue, (and if you think about it, it would be a pretty big one, and not just for the EdgePro), this would have come up long ago. If you're basing it on just one blade, I'm sure you know there could be a multitude of reasons for what occurred. So, to clarify, how does a precise bevel contribute to increased wear and chipping?
cbw
out of all the sharpening knick-knacks I've owned over the years, I keep going back to free hand on some norton water stones, and the mousepad sandpaper trick for convexes. For things with odd shapes like serrations or recurves..... this is really gonna show my ethnicity...lol I wrap sandpaper around a chop-stick![]()
Stone wear is one of the small issues, if you want me to use one so bad send me one and I'll review it.
Its simple geometry, I've tested it many times with many steels and always get the same results. Draw the two shapes out on paper or just imagine the cross section.
I ran some numbers on the subject (I tutor geometry so it was a fun practice problem). I urge you to do the same...the grind angle can change if medium thickness changes...the magnitude of the "issue" has everything to do with your expectations and standards.
To your point even a very careless user will not likely even recognize much issue...and will get good results. But if you cultivate ignorance by never understand the potential limitations of your sharpening method (regardless of what it is), you could be missing out on BETTER results. That is all I am saying.
The EP is a very nice system. There is no mystery why it has a big following...and it is deserved. But if you look objectively at ANY sharpening method, you should be able to find some limitations.
I don't think I need to add any more.
Well, it doesn't answer what I asked you at all.
I guess maybe I owe you an apology. I'm sorry I'm not dazzled by your shiny bevels and whittled hairs, and will accept what you say as gospel because of it. I'm sorry that I didn't just ignore it when I saw you posting about something that you were wrong about. Although it was about the EP, this really isn't an EP issue.
And I'm disappointed that you don't want to engage in a conversation and present something that others could learn from.
Really, forget about the EP, at this point. I'm more interested in the bigger issue you brought up.
cbw
Unit, you are correct. I've done the same analysis myself. I already stated it in a previous post. The actual change isn't even a degree. And like I also said, practically, it doesn't seem to have an effect. I guess I should clarify that. If you get to the point of using the tapes to put a very precise edge on the bevel, then yes, you do have to make some adjustment. Or if you're like at least one guy I know who measures down to the 1/10th of a degree the edge he puts on a knife then yes it matters. But for the most part, in theory it's there, in reality, it doesn't matter. And I've looked at it many times. It will matter with some of the aftermarket stones now being sold, because there's a larger difference in thickness.
Edit to add: If you're coming up with a bigger difference in the math, I'd be interested to see it.
cbw
And I'm disappointed that you don't want to engage in a conversation and present something that others could learn from. - cbwx34
