SteelDriver said:
As far as vanadium goes, it refines the grain and improves toughness. The extremely fine grain of 3V is a big reason for its outstanding toughness.
3V doesn't have outstanding toughness compared to carbon steels. It is only a standout compared to high carbon stainless steels.
As for hard impacts, I chopped concrete this weekend. The edge chipped readily, in the visible, +half mm deep. Which I would expect given the performance on the knots.
Yes I have done it with INFI, many times, rocks, nails, etc., normally while limbing, splitting etc. . It happens. Pick up a piece of wood off the ground it will be covered in dirt. Cut a tree with deep bark and it is the same. Unless you wash everything you cut outside, and carefully check every shrub for underlying rocks and never glance a cut - the edge should get damaged on a regular basis. On INFI the edge will get mashed in or roll.
In regards to the Battle Rat in the above, the edge thickness isn't what is important but the edge angle. The edge angle isn't obtuse compared to other knives, in fact it is more acute than many customs. it didn't get damaged because the hardness is high enough to prevent flattening and soft enough to give it the necessary toughness.
This wasn't by chance, the knives were edge set at at a wide range and tested inbetween until the performance was reached. Then the spine was tested over a range until the required amount of flex and strength was obtained. This isn't a case of lets ask Crucible or let some heat treater decide. It is lets evaluate the cycles over a bunch of ranges and see what works best for what we want. A lot of time and a lot of broken blades later and a knife is born.
As for the performance of Busse's knives, it isn't simply because of the steel, it is because of the knowledge of the man. Busse would make a solid survival knife out of ATS-34 if he was asked, it however would *NOT* be the same geometry as his INFI blades as ATS-34 does not have the toughness nor flexibility so the shape would have to be adjusted to compensate.
The amount of R&D that he does is insane. The biggest difference between Busse and others can be seen by noting the responce I got on Knifeforums when I asked Hossom how his new line of knives could take an impact or flex. The thread went on for pages with lots of interesting character attacks and introspections, but absolutely *NO* information given about performance. Which quite frankly I expected, but I always give someone the benefit of the doubt.
Go to Busse and ask the same questions, well you don't need to because its on the web. But ask them something else and watch what happens. His knife designs are based on performance and thus questions on performance do not bother him because he knows the answer. He routinely flexes, impacts and generally lays into his knives with a lot of ass. And yes, they do rope cutting, 2x4 chopping besides.
-Cliff
