- Mar 2, 2013
And to add, it's the secret the pros want kept in the bag because it makes them look exceptional
I assume the tar and heat helps drive moisture out of the wood, maybe the tar also acts like a glue of a sort.
I've had a closer look at a pine here next to the house and it looks similar to this description though the #1 section's about four feet. Still to early to get into the pines up high for a look and then comes the matter of hauling and cutting.Och ja...
There's an Old World principle that rarely if ever comes up on this side,and it is this:
Any coniferous tree is divided into 3 very different sections.
1.From above the bole to the beginning of any (significant) branches.
2.From beginning of branches to where the branches,almost suddenly,get Much larger in dia.
3.That last section where branches keep getting larger relative the trunk size,the taper of this section also increases dramatically.
Ideally,the builder designs the elements of the future structure so as to not Mix these first two sections(#3 is not usable in structures).
Their taper differs,also the rate of their shrinkage(especially for horizontal log construction).
At a given locale,a given species of a certain size(that are normally harvested not far from each other) have a pretty well set length of those sections.
For me here,White spruce would have the #1 section of 18' average,and #2 a tad longer,maybe 20'.
So if (IF!) a guy could design a structure where all lengths conform to the above(jog it as much as you have to),one Can,conceivably,build a place out of #1 timber section entirely.
Given the lack(or rather minimum,in reality)of twist,one can possibly then finish the place by hewing with Piilu...
(what a lovely job it'd be,too!...alas and alack,such selection is Entirely impossible for me locally).
Notes:Here's a video showing how to hang a billnäs. I found it interesting because he uses a flame and pine tar. I don't know the specifics but I was told by my dad once that granddad used fire somehow when he hanged an axe, he was suppoed to be quite particular about axes. I wonder if he did it like the person shows in this video. I assume the tar and heat helps drive moisture out of the wood, maybe the tar also acts like a glue of a sort.
I started hanging my piilu last night but I found myself working to the same style and I accidentially made the taper lean forward too much. I have to make a new blank. I will save this one though, might be able to rework it for an ordinary model 12.
Looks like a 12/3 and in need of a regrind.
