A brief review of the long sleek #89 Melon Tester-Riverboat Gambler:
As previously reported, I've not had the opportunity to handle any of the #89 pattern GEC's. My first impression was that it was dainty, but wait, upon opening and examining the build, it is built with heft. Thus my earlier statement-a ballerina that knows kung fu. It is a mere 3/8" to 1/2" wide by the same high-for the most part. Think of the narrow sharpie markers. At 4" long, if I had a fifth finger it would fit comfortably. The thought process to pack the two blades into this single spring version was well thought out as well as executed. Like my #53 TK Cuban, the main blade is offset prior to being ground to make room for the pen, while maintaining full blade thickness at the tang adding strength that equals the thickness of the backspring. The main has perfectly symmetrical machine cut swedges which differs a bit from my TK. The pen side employs a catch bit with a long drawn swedge to help clearance with the main. I think what makes this dainty knife tough is the blade and backspring thickness. It is very thick stock for such a nimble knife. Its small but long, its tough but nimble. In fact I'd say the backspring stock is the same thickness as the Broadway I bought recently, or very close.
It is well executed in appearance and function. The pull is a 4 or 5 but snaps to the open and closed positions with vigor. My TK's pen is a bit stout to open and close, but this Gambler's is just as easy as the main. The double ringed and pinched bolsters are classy and the stag on this one is very nice. The transitions are smooth at the corners while having one area that drops in below the bolster-hey-its stag. Cory-Thank You! I will put this one to use and it will have a well earned patina.
As far as ease of carry-I'm an engineer and often meet the stereotypical look with a mechanical pencil in my front pocket. The Gambler is so svelte, it could hide in a pocket protector. Even with a 4 to 5 finger grip, this knife absolutely disappears due to its thinness and short height.
Here are some very poor pics as the outside lighting is not cooperating and my techniques is that of a novice.
A Side Profile Comparison: 85, 89, 92, 38
[/URL][/IMG]
A Plan View Comparison (L to R): 38, 85, 89, 92
[/URL][/IMG]
A comparison with what could be the Gambler's big brother-S&M Sleeveboard-only 1/2" longer, twice the thickness and twice the height-nimble worker to an absolute tank.
[/URL][/IMG]
[/URL][/IMG]
Cory-Thank You Sir!
