America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Two minor points...
Blade krinking can lead to blade breaking. It's been mentioned before, but I though that this point should be emphasized. If you're dying to try it, start with an already broken knife as similar as possible to your victim.
The second point is ninety percent curmudgeonly: The obsession over blade clash or centering is largely internet driven. Lots of perfectly good knives, cars, escalators, and root vegetables get ruined every year by owners or brothers-in-law reading something on the internet and going at them with a vise and hammer. The trick is knowing when to leave well enough alone.
Pinemoon What kind of steel are the knives?
The big unknown about doing that on knives is are the tangs annealed? Every company does or did things differently. I'm sure some companies don't anneal them at all and skip the crinking completely, letting the blades fall where they may. Trying to crink one of these blades is a recipe for disaster. Sometimes you have to whack a blade pretty hard to get it to move, but not knowing the hardness of the tang is really taking a chance. That's why I say unless the blade is actually rubbing the liner you might be better off leaving it alone. Of course if it's a cheapo disposable then whack away.
You definitely don't need a chisel with a 7oz hammer, I only mentioned that for those folks who only have something like a big claw hammer or framing hammer. etc. Those are a bit on the large side
The mallet I used in the video was one pound including the handle, the head was probably about twelve or 13 ounces by itself. I crinked everything from little whittler coping blades to big 'ol folding hunter blades with that hammer. The important thing is knowing how hard to hit the blade, and the only way to master that is through trial and error. Believe me I sent folks ducking for cover more than once!
Eric
The steel on the Boker is C75
The Rough Rider just says 440
Thanks Eric,
Some good insights there. The Rough Rider I'm trying this on is a cheapo so I'm game for whatever.
One question I have is , are we trying to move the blade/tang on the pivot, or are we trying to "curve" the blade a bit, or something else entirely?
Thanks for your input.You’re trying to bend the blade.
I haven’t tried this method and it certainly looks interesting, but I think it’s a bad idea to do it this way. It’s a lot of force very quickly in a very concentrated area. The way I’ve done it, and I’ve done it numerous times, is to put the blade in a vise and bend it that way. I think it greatly reduces the risk of breaking the blade but also adds to the options of centering, because if the blade won’t bend generally the frame will, it seems that depending on if it is the blade that is bending you have to bend in the opposite direction as if the frame is what’s bending. If you put the blade in the vise with the tang visible you can bend it there, this can loosen the blade but it can be re-piened. I have started putting a small screw clamp on either side of the bolster to keep it from loosening which works well.
Keep us posted on that. I'm glad you have the intestinal fortitude to experiment. I can't bring myself to do it with a knife I've hardly used.Thanks for your input.
I will try the vise technique on my Rough Rider. It's my "experiment" knife![]()
Haha, will do.Keep us posted on that. I'm glad you have the intestinal fortitude to experiment. I can't bring myself to do it with a knife I've hardly used.
This is my guess on this one.Thinking a bit more, I'm probably encountering what Eric said earlier. The tang probably isn't annealed on the Rough Rider. I doubt these budget pieces have that extra step.
Thanks for your helpThis is my guess on this one.
Chestnuts don’t even have very hard shells. Could it have softened while grinding or something? Regarding blade centering I decided to give the hammer method a shot, it didn’t work for me, I’ll post pics, the first is after trying it, the blade didn’t move, could have done something wrong but I don’t think so, and I had to hit it with a hammer harder than I think I want to. The other pics are of how I currently center blades and the results.Slightly off-topic but this has to do with bending blades.
If you can krink, bend or straighten a blade, much may depend on its hardness I suppose? Trying it out on D2 which I think has a RW hardness about 61 on former Queen knives could be tricky, snap!but the opposite seems true on softer steels. Over Christmas I got out a Wright's Sheffield Ettrick which I thought would make an excellent knife for slitting Chestnuts to make sauce/stuffing with. The Ettrick is a short bladed Wharncliffe with a long handle-just right for scoring the Chestnuts, so I thought. Turns out not
Now Wharncliffes can have a notoriously fragile tip, leading to breaking, but I imagined that as it was a very short blade it would be OK and Chestnuts are not that tough either, they're not Almonds
The tip did not break but it curled over like an opened tin
can't imagine how soft that steel must be but I had a curly tip after a couple of Chestnuts. A SAK with a small pruner finished off the job with no scars-and SAK stainless is fairly soft anyway, but that Wright seemed like a lead blade, back in the vice and all straight but it loves to bend....
